Thanks PWR RYD. I cut these on a universal laser systems VLS4.60 I have access to at a school. I wish it was more powerful for cutting through thicker hardwoods but I'll have to do more experimentation. It cuts with a v-shaped kerf on thicker materials so the outside of the fingers have gaps, but fit tight on the inside. This is why the fingers are outlined in black. I'll need to do testing, but cutting recesses for drivers doesn't seem feasible.
Vigor - a laser cut knockoff of a cardioid design
Keep us posted on how they turn out djg.
Love the look of these! My taste can be a bit weird at times, but I liked them even more before you sanded the burned fingerjoint ends. If you were to sand the faces of the panels prior to assembly, but leave the burnt ends, IMO, those would look awesome due to the contrast. Either way, I really like the cabinets, nice work man!
- 1 like
Those came out super.
Man, who needs a table saw when you've got Darth Vaders stinking light saber!
Unique to say the least. What does it smell like when it's cutting?
TomZZarbo Audio Projects Youtube Channel: https://www.youtube.com/channel/UCEZ...aFQSTl6NdOwgxQ * 320-641 Amp Review Youtube: https://youtu.be/ugjfcI5p6m0 *Veneering curves, seams, using heat-lock iron on method *Trimming veneer & tips *Curved Sides glue-up video
Thanks everyone. Yes, the burnt ends do give them a neat contrast. The laser cutter has an exhaust fan that pulls away most of the smell/smoke when cutting, but the pieces do have a burnt wood smell that lingers and there is a bit of soot on the pieces. It smells much better than when I cut acrylic.
Originally posted by a4eaudio View PostSilverD...
1) Your build is awesome
2) I saw a post of yours in another thread and I knew you had done these and wanted to go back to this thread. But...you need to add the link to this build in your signature.
Originally posted by Derekj View PostCool project! How thick is the cut from the laser - less than a 1/16th?
Hi all,
I have had a few folks ask about flat pack availability. I'm looking to see what kind of interest there would be for a flat pack of the Vigors made from laser cut 1/2" baltic birch including 3D printed ports. I mentor a high school robotics team and have a graduating senor who is really into machining and fabrication. With the current state of affairs, unfortunately our season was cut short. Instead we are now creating PPE to donate to organizations in need. This allows a few students access to our tech facilities, including a laser cutter. We are optimizing the design for the laser cutter bed size and material usage. The student will be heading up the machining and delivery of the flat packs.
Thanks,
Nate
