Safineia is Greek for "clarity" which defines this combo pretty well. For this build I selected the Rival Acoustics R176P08 woofer and the ScanSpeak R2604/8330 Ring Radiator tweeter. I have used a few of the Rival woofers over the last year or so and can say they really are a great piece of gear. This time I made use of the paper cone version. It did not disappoint. There really is no cone breakup to speak of. The on axis response is pretty flat to nearly 5k where there is diffraction from the surround. The 430Hz Fs of the ScanSpeak tweeter results in a very large overlap of flat response.
The enclosure is a pretty straightforward affair. Nothing particularly difficult. This was very purposeful as the supplier for the Rival woofers has made this and another build as a kit in which they include the baffle. For my version, I used 3/4" BBply for the top, baffle, and bottom with an extra layer of 1/2"BBply on the baffle Sides and rear are 3/4" MDF. The ply is finished with 2 coats of dewaxed shellac. The MDF is finished with multiple coats of Rustoleum hammered black and silver. The enclosures were then sealed with 3-4 coats of Rustoleum frosted pearl seal. Overall dimensions are 16.5H 9W 14D for a net volume of .75 cu ft/21L The rear 2"x6 port results in an Fb of 40Hz and F3 of 38Hz. There is 1 brace connecting the sides, top, and bottom and one more between the rear and the brace.
