I am finally coming around to replacing the exaggerated subwoofer I built for my modernized radio console project, http://techtalk.parts-express.com/fo...onsole-project.
My first attempt was a sealed Dayton Audio UM8-22 pushed by a Yung SD300-6 300W. It would shake the cabinet because it was coupled but also the house. It overpowered the TriTrix MTM TL powered by a 100W amp. I was thinking about staying between 50-100W for the new subwoofer. The cabinet needs a subwoofer as it really sounds hallow and I hear no lows. I was thinking about two options but I I wonder if I am off here.
First is using the Dayton Audio SA70 70W plate amplifier (45 watts RMS into 8 ohms @ 0.1% THD • 70 watts RMS into 4 ohms @ 0.2% THD ) pushing a Wavecore SW146WA01 (4ohm 55 RMS) or the SW118WA02 (8ohm 40W RMS).
The second option is the Dayton Audio SA100 100W plate amplifier (75 watts RMS into 8 ohms @ 0.1% THD, 100 watts RMS into 4 ohms @ 0.2% THD) using SW146WA02 (8 ohms 55 RMS) or Wavecore SW146WA01 (4ohm 55 RMS).
An option 2b would be SA100 with slightly higher power like the DCS165-4 and SW168WA01 both at 100W RMS at 4 ohms. My issue with these are larger sealed or vented enclosures and I feel I’m inching toward having the same problem I had with the 300W subwoofer. I want to keep the enclosure inside the console. I will isolate with rubber pads as suggested in the original thread. The sealed or vented enclosure for both SW118WA02 and SW118WA01 make impossible to install the plate amplifier in the same box. at least i think so.
Hit me. What am I missing?
Secondary question. what is preferable, 4 ohms or 8 ohms?
