I've wanted to get this design on paper for a while. My dad did a pair of large 15" 3 ways when he was young, and I grew up with them as inspiration to get into speaker building my whole life. They were designed with tools at the time, which were basically text book 2nd order crossovers and adjustable L-Pads on the tweeter and mid to bring the levels in. I have no idea what drivers he used, I do know that it was a 15" woofer, and a paper dome mid and tweeter. The design was set on it's side, with vertically oriented mid and tweeter next to the woofer. He originally did it ported, but didn't like the sound so he sealed them up. I'm pretty sure he didn't have the correct port calculations though, based on us building boxes later in my teens.
He passed away in 2015, just before I learned all these sweet DIY crossover design tools. So this design is a tribute to his work in the 70's, I'll call the JPG Tribute. Also, since I don't have a purpose or place for speakers this size the design will remain theoretical for me. All Dayton drivers designed using their FRD / ZMA files, processed with response modeler to add baffle and diffraction signatures processed to minimum phase. The acoustic offsets, particularly the Z offset is guestimated, so some minor adjustments are likely if these end up in real life by anyone.
Drivers:
DC380-8 15" woofer
RS52FN-8 dome mid
RST28F-4 tweeter
Design aesthetic: The originals had an inset baffle with a classic tweed fabric covered grill, so I'm doing that here as well. He actually used particle board, and stained and poly coated it for a deep color with the fine chips of the particle board visible through the stain. Looked pretty good, but this would be nice in a BB ply as well.
Woofer Alignment:
The volume was dictated by my estimated size of the originals, a solid 5.8 cu ft. That puts a a vented alignment tuned to 23Hz with a 4" x 7.7" port in line for the DC380-8 woofer with an F3 of 30Hz. Sealing the port yields a low box Q of 0.48 with an F3 of 52.
Vented
Vented Vs Sealed
In my opinion, either would work well. The DC380-8 does run out of Xmax a bit though, so a full 100W and 110dB of output will get you some over-exertion.
Drivers:
DC380-8 15" woofer
RS52FN-8 dome mid
RST28F-4 tweeter
Woofer Alignment:
Vented
Vented Vs Sealed
