UM18-22 Flat Pack Build (step-by-step)
  • jtwrace
    Thanks!
  • ceiol
    nice write-up. some serious subwoofers!
    Nice documentation, thanks.
  • jtwrace
    And finally the completed sub with a measurement:
Name:	UM18 scaled.jpg
    Still looks small compared to my other diy sub:
  • jtwrace
    I was confident that it was all correct as I always check each step; however, it's so much easier to check now as a complete assembly...
    Click image for larger version  Name:	Battery Polarity2.JPG Views:	0 Size:	97.9 KB ID:	1451636
  • jtwrace
    Install the driver!
Name:	bolts installed2.JPG
  • jtwrace
    Stuff it!
    Click image for larger version  Name:	Stuffing2.JPG Views:	0 Size:	39.5 KB ID:	1451632
  • jtwrace
    Next was to solder the Belden 1313A to the Neutrik speakON and install into the cabinet
    Click image for larger version  Name:	Soldered speakON2.JPG Views:	0 Size:	46.2 KB ID:	1451630
  • jtwrace
    Now you might be wondering what it looks like underneath? Of course, I'll show you a terrible pic!
    See how it squeezed out evenly? Now you might want to touch it and remove the extra. Do not! Why? You run the risk of getting it on the bolt and not even knowing that and then when you go to remove them, you realize what happened.
  • jtwrace
    So the little teeth on the Tee Nut are obviously meant to penetrate the substrate - MDF in this case. If you hammer them in, the teeth get bent and mangled and usually cause more harm than good and also put the Tee Nut in crooked which can lead to cross-threaded bolts. That is a nightmare!
    So using those grade 5 bolts and washers you "draw" the Tee Nut up into the substrate. DO NOT tighten too tight, just enough to squeeze the extra PL out and hold it. Remember: The PL is really what is holding the Tee Nut, not those goofy teeth. I personally like to leave the bolts in for 48 hrs to make absolute certain the PL has fully cured.
  • jtwrace
    Now this is very important. If you get the PL on the threads of the Tee Nut, you're screwed!
    So I put 3 dabs around the side of the Tee Nut like below.
Name:	PL on T nut2.JPG
  • jtwrace
    I really dislike drivers being held in with wood screws. If you ever need to remove a driver more than once, the hole is usually buggered up as it's not really made for multiple disassembly. So how does one deal with that? Tee Nuts! This is how I use them...
    First you need to purchase some quality tee nuts as these are meant for a permanent installation. I will be using SHCS as my finish bolt to hold the 45 lb 18" driver in.
    So you get the Tee Nuts and some basic grade 5 bolts with washers along with PL Adhesive as seen below. See where this is going?
Name:	T Nut Install2.JPG
  • jtwrace
    Next up was waiting a few days for the Duratex to harden (takes up to 7 days) enough to handle the cabinet. Spent lots of time on the water during this time.
  • jtwrace
    2-3 coats of Duratex provides an excellent finish. I have found that while you put it on heavy, it really takes rolling it in all directions to smooth it out evenly. Then for the final finish, you slowly roll one direction with no pressure with 50% overlap. No zebra stripes and a consistent texture
Name:	finished baffle2.JPG
  • jtwrace
    I like to finish the inside. If it was ever sold and someone opened it, I like it to look finished. Also, it really cuts down on the possible MDF dust and just makes it so much nicer to me. How crappy is it to open a speaker and see it raw and cheesy inside? Yuck. Doesn't take much more effort to make it look a bit nicer and an advantage of diy since you're not against the Excel Sheet of the bottom line
