Next build, cjd's Abourious
  • #16
    • #17
      Aha! I like it.
      • #18
        Looks like you'll have a very smooth flow of electrons there!
        • djg
          djg commented
          Editing a comment
          The XOs came out pretty nice.
      • #19
        Mahogany PSA veneer. Electric was out all day yesterday. I read a book.
ID:	1476240 Click image for larger version
        • #20
          Stain or just oil finish going on these?
          The fit and trim work is top notch.
          • djg
            djg commented
            Editing a comment
            The sled I made for my tiny table saw really helped with accuracy. I'm using a formula from youtube.
            Equal parts of Minwax poly, mineral spirits and boiled linseed oil. It looks good on a sample of veneer. No stain.
        • #21
          One coat. i have the baffles to lay out and rout. cjd crowded the drivers to almost touch, leading to tearout and patching. I will give them a bit of space. 1/4" or so.
          • djg
            djg commented
            Editing a comment
            4 coats brushed on, wiped off. I added more poly to the last coat. Semi gloss sheen to match the TV stand, if not the species.
        • #22
          Nice - looking really good. The mix sounds similar to a danish oil. Does it progressively build up a bit of sheen?
          Constructions: Dayton+SB 2-Way v1 | Dayton+SB 2-Way v2 | Fabios (SB Monitors)
          Refurbs: KLH 2 | Rega Ela Mk1
          • djg
            djg commented
            Editing a comment
            Thank you.
        • #23
          This is 6 coats with progressively more poly in the mix, with Johnson's paste wax.
          • a4eaudio
            a4eaudio commented
            Editing a comment
            Those are looking really nice. Can't wait to see the front view with drivers when finished.
          • djg
            djg commented
            Editing a comment
            Thank you. Heads up, the baffles will be painted MDF. Probably black.
        • #24
          Those really are coming along nicely.
          Are you adding JPW to the mix???
          • djg
            djg commented
            Editing a comment
            Sorry, the wax is put on after the finish dries.
          • Steve Lee
            Steve Lee commented
            Editing a comment
            I've stopped palpitating, now - thanks for the clarification!!
        • #25
          • #26
            Here's the current HT setup. The S2000 L/Rs are hung off the rail. Originally I had S2000 TMs for L/R. I want the speakers to be lower, not extending above the rail. Thus, low stands with a tiltback angle to properly direct towards the MLP.
            It's possible I might construct a new minimalist center speaker/ TV stand using a wall mount bracket grafted onto a single center post. And L/R stands to match.
            • silverD
              silverD commented
              Editing a comment
              8.1 sound! They look great!
          • #27
            Two down. The crates put these right where I plan to position them with stands.
            These speakers sound really nice. So glad I made them. Just listening to cable music in stereo with 80 hz sub cross. As far as lightweight, still pretty heavy.
            • #28
              They look great dj and glad your already pleased with their sound quality! Curious at some point how their sound compares to S2000's ... and ... stands or subwoofer stands?
              • djg
                djg commented
                Editing a comment
                My aural memory is pathetic. The new speakers seem a bit fuller maybe? I have all 3 done now. I will listen to some epic bluray later today. Even I will not be able to tolerate those crate stands for long.
                I will post more pics when I have made some furniture progress. I have one sub in the rear corner.
            • #29
              Click image for larger version  Name:	IMG_0001 (28).JPG Views:	0 Size:	383.5 KB ID:	1476816 Click image for larger version  Name:	IMG_0002 (14).JPG Views:	0 Size:	415.2 KB ID:	1476817
              So, these are 20" x 12" x 7.5". They are braced 1/2" particle board. 1" mdf baffle with a 3/8" roundover.. I moved the woofers apart to give some meat in between the drivers. I used cjd's generic Seas crossover. These are sealed. The 1/2" thick cabs allowed some size reduction at same volume. Same baffle width.
              cjd shows 3/4" plywood vented design on his webpage. His woofers were as close together as possible. He used a 3/4" roundover. cjd drew sealed, vented and tower variations. I do not know if he built any but the vented ones on his webpage.
              • #30
                Very inexpensive stands. Black prefinished shelving. Cut, hot glued to keep things in place, then screwed together. I may make some C shaped stands by laminating straight pieces with finger joints. If I don't like these. 5 degree tilt.
                Click image for larger version  Name:	IMG_0001 (31).JPG Views:	359 Size:	451.1 KB ID:	1477043
