I just unearthed a couple def-tech buyout woofers after some recent posts reminded me that I may have used them long ago as door speakers in a previous vehicle. Lo and behold, I located them and they had collected a decades worth of dust in the basement. Since I only have 2, a quick search led me to Wolf's Deuterium design. I dug up some silkies and ordered the required crossover components. I built the cabinets from 1" x 12" poplar boards bevel cut on my 12" sliding miter saw to form the sides, tops, and bottoms. 1" x 6" poplar boards were used for the baffles and backs. I 3D printed the ports. I still need to assemble the crossovers and finish the cabinets. Here are some pics of the progress.
Blast from the past
Blast from the past
Tags: None
Pretty handsome speakers. Small enough to make without guilt.
TomZ
Nicely done! I haven't seen those in a bit...
Thanks everyone. I tested the speaker without a crossover connected to my modified Ikea Symfonisk Sonos. In my testing, it looks like it uses a 1.8kHz crossover point which I think is similar to the Deuterium crossover point. It sounded a bit lacking in the highs, but a boost in the treble via the app EQ helped. When I ran the Trueplay calibration I ended up losing mids and noticed a low bass and high treble boost. I noticed this in my testing of the Symfonisk as well. I plan on assembling the crossovers and testing them with the Symfonisk to see what difference this makes and will then compare this to the speaker being powered by a conventional amp. If I find that the Symfonisk does a good job, I may transplant the Symfonisk guts to the Deuterium.
I bet there are STL files of ports you could find, but there are many free CAD apps out there. OnShape is a great web-based CAD program that is free for students and hobbyists/makers.
This speaker is 14"t x 7"w x 11.25"d built from 3/4" poplar boards. The 1" x 6" is a solid board and the 1" x 12" is laminated. With a 3/4" baltic birch brace in the middle, the speaker is very solid. I plan on adding butyl dampening and some foam.
