Despite all the negativity conjured up whenever someone mentions RADIO SHACK, I miss that retailer. During the 70's & 80's they offered many fine components and an enormous assortment of speakers systems.
I bought a pair of MACH ONE speakers in the latter 70's. The 40-4024A. My very first hifi purchase. And I've always regretted not keeping them.
To rebuild them using many 40 year old parts does not really make sense to me. So, I redisigned the MACH ONE with modern components.
Of course, I used the GRS MACH ONE REPLACEMENT WOOFERS from PE. And, yes, these woofers do offer the same warm bass tones as the originals.
I found a NIPPON bi-radial horn lens measuring 16.5"x 6.25" x 9" which approx mimicks the original MACH ONE horn (16.75"x 4.5" x 9"). These NIPPON lenses offer curved protruding lips reminiscent of the MACH ONE horns. Their bi-radial design provides exceptional spaciousness and an almost 3-dimensional sound. Very nice. The throat is a standard 1.375" x 18 TPI with a metal threaded insert.
As for the midrange horn driver, I used a TIMPANO AUDIO compression driver, purchased from PE. These TIMPANO drivers are solidly built of die cast aluminum, much superior to the original horn drivers. The TIMPANO diaphragm is Phenolic, which I chose to keep the same as the originals. Phenolic diaphragms tend to sound natural as compared to metal midrange diaphragms. The TIMPANO diaphragm measures 2" diameter. This is a good size for a mid-driver and is less likely to distort near the lower crossover point.
The original MACH ONE employed a plastic small rectangular bullet horn super tweeter. I found a pair of PYRAMID super tweeter bullet horns here at PE. The overall dimensions of these horns is 3.375" diameter. They are solid die cast aluminum. Again, much superior to the originals. Their actual horn measures 1.5" diameter. These horns use a Titanium diaphragm and are ferro-fluid cooled. This fluid also aids in damping diaphragm movement.
My old MACH ONE speakers featured crossover points of 1,200Hz and 4,500Hz. I always felt they sounded slightly shrill and/or pinched in the midrange/treble region. The original MACH ONE crossover was 800Hz and 8,000Hz. I decided to go with the original design, as they are said to sound the best of all the MACH ONE versions.
i researched the MACH ONE crossovers. I cannot find any modern crossover model which corresponds to the crossover components of the original MACH ONE. For instance, the originals employed a 33uf cap with a 3mH coil for a -12dB low-pass 800Hz woofer crossover point. These values do not correspond to Riley-Linkwitz, Butterworth nor Besel 2nd order crossovers.
Also, I may have found a flaw in the original's crossover design. From what I could find, the originals incorporated 2 resistors, 4 caps but only 3 inductors. Therefore, it is my guess the MACH ONE crossovers offered -12dB slopes for the woofer and bandpass, but may have only offered a -6dB 1st order crossover for their super tweeter. This may account for the shrillness I sometimes noticed, due to excessive overlapping of mid and tweeter drivers as well as the tweeter playing frequencies too near its lower end limitations.
So, using the Riley-Linkwitz model, I designed an 800Hz/8,000Hz full 3-way -12dB crossover utilizing 4 caps, 4 inductors and a 4 ohm padding resistor in series with the PYRAMID tweeters (as they are rated 4 ohms).
The TIMPANO midrange drivers claim a response range of 400Hz to 8,000Hz. This is almost an exact match to the original's midrange of 800Hz to 8,000Hz. The TIMPANO's suggested lower crossover point is 500Hz.
The PYRAMID super tweeters have a claimed extended response up to 25,000Hz. This is also an exact match to the original MACH ONE tweeter's claimed response of 25,000Hz.
I also bought 15 watt 8 ohm mono L-pads from PE. The original MACH ONE offered mid and tweeter level controls. The L-pads are definitely required. As you can see in the pics, the horns are turned down substantially.
Enclosure construction is simple 5/8" particle board with a vinyl laminate birch wood finish. The baffles are painted gloss black.
The original MACH ONE featured an internal shelf which separated the midrange section from the woofer compartment. I also included this shelf. The shelf also acts as cabinet reinforcement.
The original MACH ONE featured removeable rear panels to access the mid and woofer compartments. I chose not to do the same.
The original MACH ONE had poly or fiberglass damping suspended from the internal shelf, behind the woofer, not unlike curtains on a window. I used about 0.6lbs polyfill for the woofer section and about 0.1lbs polyfill in the midrsnge compartment. I purposely did not overfill as my experience indicates less is better than too much.
The original MACH ONE grilles were a brown foam type. PE carries 3/8" foam grill material which is easily cut to size and attached via velcro, just as the originals.
The terminal cup is a standard spring-loaded type. The original MACH ONE featured old fashioned screw type terminal connections.
The original MACH ONE measured 28 5/8" x 17 3/8" x 12". My redesigned MACH ONE is 31 1/2" x 17 3/4" x 11 1/4". The difference in dimensions is due to the NIPPON lens being slightly larger in height.
The original MACH ONE had a rough woofer Vc of 1.75ft. My enclosures are approx 1.89ft. Original Fc was rated 65Hz. My Fc should be about 60Hz with a F3 of 63Hz. Originals weighed 65lbs. Mine weigh 59lbs.
The sound is AWESOME! Playing MARIAN HILL's Breathe, I cannot believe the depth of her voice. Treble is extremely smooth and subtle. No harshness whatsoever. Bass is full and deep. As stated in the beginning, the sound is almost 3-dimensional. I love these speakers. Very impressed with the outcome.
I have a YAMAHA 5.1 receiver which I play in 2 speaker stereo mode for music. All tonal controls/EQ flat except for a 2.5dB boost in BASS control (50Hz).
