In addition to working on my home theater and learning passive crossover design I have been building some speakers for my new business. I have had an original Continuum kit from Meniscus for the last 5 years waiting to be built. I have built the cabinets for these boxes at least 5 times, they just never turned out the way I wanted.
Well, when Jeff Bagby passed away earlier this year it motivated me to finally complete these speakers. I wanted them to be something special.
I also designed a subwoofer to go with these, it is called The Skausmas sub. Skausmas, in Lithuanian, means pain. I am opening a pain clinic in two weeks where these will live so it fit.
Each subwoofer cabinet had a Scanspeak Discovery 12” sub and a pair of matching passive radiators. I’ll post the technical stuff from my computer later. Each sub is powered by a SpeakerPower SP1-700 plate amp housed in its own sealed sub enclosure within the box.
All the speakers are finished in House of Kolor Jet Black with KC21 flat clear. The baffles are chamfered around the edge and are finished in a beautiful copper veneer and finished with House of Kolor USC-01 show clear. I modified the Continuum design to not have a removable front baffle, the woofer reverse mounts into blind threaded inserts through the removable rear panel. The removable rear panel is finished in piano gloss black using House of Kolor Jet Black and USC-01 show clear. I also designed and built integrated stands for them with a speakon connection at the bottom of the stands. I ran out of threaded inserts so a few are missing from the rear panel right now.
The speakers are powered by a Marantz MM7025 amplifier. The preamp is a MiniDSP SHD with integrated DiracLive. The input device is a SMSL SU-9 DAC. I built a custom remote box that powers everything with a single button push.
-Trevor -Trevor
