TWF6 desktop speaker
  • #16
    Looking Good!
    I'm jealous of your woofer recess, that's nice.
    TomZ
    • #17
      I thought I should finish this build diary, so here are some more pictures and details.
      • #18
        Base module for the Bluetooth amp, batteries, charger, and battery status panel.
        • #19
          Front panel battery monitor display and ON/OFF
          • #20
            Bluetooth amp
            • #21
              The finished base with all the parts fitted - a bit tight!
              • #22
                Schematic of complete speakers.
                TWF 6 speaker schematics.pdf
                • #23
                  The finished speakers, taking pride of place on my desk.
Name:	finished speakers.jpg
                  • #24
                    Nice results, nice documentation, thanks.
                    • #25
                      They're beautiful. That's some next-level engineering going on there in my opinion. I'd botch the electronics in that all up guaranteed. I especially like the integration of the electronics into the bases. Nice work!
                      You've nearly doubled the interior volume, I wonder how do they sound?
                      TomZ
                      • #26
                        Pride indeed, they look great. are you charging them off USB?
                        Edit, i completely forgot you already answered the USB thing. I would be keep to know how you managed to do this as i've heard mixed outcomes about overloading a wall wart which can cause a short\fire etc. I really want to do somethng similar with an upcoming 2 builds so very very keen to know how you did it.
                        • #27
                          A couple queries...
                          Shouldn't you have current limiting resistors on the LEDs? IME, even being a low draw at 5V will overcurrent them. I blew 2 sets of LEDs over this learning experience.
                          I see you have amplifier outputs labeled as HP +/- and LP + and HP - in the schematic.
                          So, you are biamping the drivers, and using a passive xover. Why did you go this route over DSP/active solutions? Just curious...
                          You clearly know more than me about the active side of electronic things to do this, so please correct me if I'm wrong.
                          Looks great!
                          • #28
                            Red. Orange, yellow, & yellow-green LEDs need 1.8 - 2 volts while white, blue, and deep green LEDs need around 3 volts to light them up. These small LEDs can only handle 10 - 20 mA of current and the higher the voltage supplied the more current the LED will draw. Running a 2 volt LED at 5 volts will fry the LED, it's only a matter of time and it could be within seconds.
                            • #29
                              This
                              I'll add explanation. A diode, LED or any type is effectively a near short circuit above it's threshold voltage. A current limiting resistor is 100% required in series with the diode. The current the diode will see is calculated by (applied voltage - diode junction voltage) / Series resistor. Target ~10mA for that current based on whatever input voltage you apply.
                              Wogg Music
