Dayton Center Channel
  • Dayton Center Channel
    I produced this center channel from what I learned on this forum. Thank you. I wanted something to put on the fireplace mantel under the TV. So space was limited. I did want the challenge to build something from scratch. So this is it. An MTM nested design with 2 Dayton TCP 115-8 woofers and a Dayton NDFA20-6 tweeter. It worked well and I am happy. I changed the schematic from the original 3.7 ohm resistor on the tweeter to a 1.5 ohm as I felt it needed to be a bit brighter. It's the only other resistor I had laying around. That worked well.
    Box has external measurements of 20" wide x 6" tall x 7" deep. It is ported with two 0.75 inch x 2.5 inch ports. The PVC was left over from my inground sprinkler repair.
    However, after all this work I am wondering if would have been better off building the OS mmtmm or just buying the somewhat similar Dayton Audio MK442.
    Nice job.
    DIY speakers is not build one, sigh in relief about being finished.
    Build more, learn, compare.
      That doesn't sound like any fun at all!
        Originally posted by djg View Post
        Nice job.
        I can understand that....but then what do I do with all the speakers I have sitting around?
        • djg
          djg commented
          Editing a comment
          I can get most of mine under the queen bed with a four poster frame. The rest just sit around.
          It's nice to give them as gifts too.
        EXACTLY !
        Looks really good for your 1st design. Box size/tuning is "reasonable", and XO SEEMs okay.
        (Just to nit-pick):
        Bringing the woofers closer together would probably improve/reduce off-axis "combing".
        I'd (personally) probably have tuned the box a bit higher (and gone w/larger dia. ports).
        A pair of 1.0" id x 4" long ports seems about right (a single 1-1/2" x 4" port would also suffice).
          Thank you. I initially did have the woofers closer together exactly for that reason. However, aesthetically it just looked a little wonky. So I moved them a tad further apart. But I did choose the nested design to help with off axis response.
          Box is still essentially unfinished. My router job to flush mouth the drivers could be better. I will likely do some additional standing, wood filler, caulk, and paint to improve its appearance.
            So changing those ports like you say would change the tuning frequency from 59hz up to 64hz. Does that really make that big of a difference?
              Not so much from a tuning/FR point, but from a chuffing point, I'd say yes.
              For my TM (in 0.09cf) I used a 1-1/4"id tube. For a pair that'd be equivalent to a single 1-3/4" tube. (You're about at an equiv. single 1"id tube now.)
                Probably not a big deal if your AVR is set to high pass at 80Hz anyway. If you're attempting to put out bass from that thing though, I'd agree with Chris.
                Wogg Music
                  Yes. It is set at 80 Hz. I will think about it. I can move it to the 2 channel system and crank it up to see how it performs. Thank you.
                    I posted this chart a long time ago and it shows what a small change in port diameter does to the area and subsequently to box tuning. Also the actual PVC internal diameters are not the nominal size of the pipe.
                      The 0.75 diameter I posted for the PVC was in the inner diameter. It has a 1 inch outer diameter. When measuring with a digital calipers it actually measures 0.79 inches on the inner diameter. I haven't noticed any chuffing when running full range, even when listening to rap.. So I think I'll leave things as is. Thank you.
                      I wonder what the size of the single port is on the Daytion MK442 shown below? Looks like it may be inch and unknown length. I also wonder how that speaker compares to what I built but I don't want to buy on just to find out. Does anyone here have one?
                        The dimensions in the chart are US industry standards and any schedule 40 PVC pipe purchased in this country will conform to these dimensions within a small, insignificant, tolerance. Custom manufactured plastic ports are another story and probably measure as advertised within an insignificant manufacturing tolerance of +/-.005 or so.
                        It's impossible to get a precise measurement of an inside diameter with a digital caliper due to the width of the blades of the caliper. The measurement takes place at the edges of the caliper blade and not the center, providing smaller than actual numbers. The blades on my cheap, Chinese, caliper measure .078 (2mm) wide which introduces a .010 error when attempting to measure an .824 inside diameter.
                        The idea behind the chart was to make sure that designers realize that the nominal dimensions of PVC pipe are not the actual dimensions and if used the nominal dimensions will introduce errors into port calculations and subsequently enclosure tuning. A 1-1/2" PVC pipe actually has an actual inside diameter of 1.610. The area of 1-1/2" diameter is 1.767 square inches while the area of the actual 1.610 pipe inside diameter is 2.036 square inches, 15% larger. The area of .750 (3/4") diameter is .442 square inches while using the actual .824 diameter provides an area of .533 square inches, 20% larger.
                        Using real numbers will push actual measured performance closer to calculated / modeled performance.
                          MK442 port dimensions:
                          Depth/length = 80mm
                          Diameter = 31.8mm
                            ...or just buying the somewhat similar Dayton Audio MK442.
                            GASP!! Leave this forum immediately!!!
                            hahaha.....jokes. Great first build.
                            I'm guessing your internal volume is around 6.5L net with port, crossover etc considered. If that's the case your current ports tune the enclosure to around 58hz.
                            Assuming the 80hz high pass mimics 2nd order roll-off the maximum power handling is around 90watts for these two woofers and at this level they are producing just north of 102-104db (a little less with the crossover factored in) but the potential issue is the port velocity with your chosen dimensions is up around 50meters a second (WITH the 80hz high pass filter) - essentially a hair dryer. Its over 80+ m/s without the high pass filter and max power.
                            Whether you hear this and find it unpleasant or not is entirely your call.
                            Two ports with an internal diam of 1inch and a length of 4.75 inch would provide the same tuning and reduce the port velocity to something more reasonable at typical listening levels (19m/s @ 100db w/ 40watts)
