Thanks Steve, I felt that this would be a great opportunity to start experimenting with active crossovers. I'm new to active crossovers, but with the winter months coming it will provide some easy tinkering. David, yes the baffles will remain natural. The two coats of shellac I put on seem to have done a decent job of sealing the end grain. I was thinking of brush/roller applying a shellac-based primer and then top coating with a matte paint. Was at first thinking a gray but now I might look to a lighter color. Wolf, do you think the epoxy is necessary after shellac and shellac primer?
DXT-MAX - Small active monitors
I assembled the second one, lined it with foam like the other, added 60 grams this time to the PR, and didn't use any Acousta-Stuf. These are over 20lbs each!
As long as it's sealed and impervious, you should be fine.
I'm thinking I'll go white for the cabs while keeping the baffle natural. Rolling or sprayed, I hope to give them some texture to help hide any blemishes. Here is a screenshot of the crossover in SigmaStudio and everything connected an running! I opted to swap in an Icepower 125asx2 amp with volume control for the tweeters to make the level matching easier and on the fly. They stack nice as well.
- Likes 1
You may never paint them. They look nice. you might want to make short stands to get them up off the desktop.
The baffles on the Schumakubins HT suite was Rustoleum stone texture.
You might be right, they might not see a color change. If they stay on the table/desk, I'll look into stands. Those foam wedges may not cut it for these heavyweights. I used the stone texture spray paint for the TriTrix I rehabbed. Sprayed over with the final paint color I wanted.
The crossover in the pic above is what I came up with as I was building the speakers:
DC blocking -> 4dB baffle step @ 600 Hz -> X-over LR48 @ 1800Hz -> split into 4 channels -> LF PEQ of 20Hz high pass / No HF PEQ yet -> gain adjustment for tweeters not in use yet.
Changed the x-over slope from LR8-48dB to LR4-24dB to match that of the DXT-MON and added a LF PEQ @ 30Hz:
The extra low end boost helped fill in the lowest notes. The healthy xmax allows for this type of EQ with DSP. So far the listening has been in a small room near field and these provide plenty of bass. I need to look at the overall FR and adjust accordingly, but they sound good so far with great imaging.
Originally posted by silverD View PostThanks for the comments everyone
Tom, I'd have to pull up the WinISD model on other computer, but I think at 70W/100dB both the woofer and PR (with 30g mass added) are under xmax with a HPF at 20Hz.
I'm so sorry, I modeled the PR with an older Esoteric woofer, not the Epique 5 1/2" sub, my mistake!
Just wanted to clear this up to avoid any future confusion.
TomZZarbo Audio Projects Youtube Channel: https://www.youtube.com/channel/UCEZ...aFQSTl6NdOwgxQ * 320-641 Amp Review Youtube: https://youtu.be/ugjfcI5p6m0 *Veneering curves, seams, using heat-lock iron on method *Trimming veneer & tips *Curved Sides glue-up video
Hi Scarface,
Besides the tweaks above, I tinkered with some filters for the tweeter. I'm still learning to take measurements and I don't have a dedicated space to take them. Throw in the fact I have a two year old and it makes it difficult to get space and time to tinker. I think they sound great, but do not have a trained ear. I do notice more hiss than I would like out of the tweeter vs a passive speaker, so I'm looking to change up my DSP a bit. I was running a chromecast audio -> optical -> SMSL SK 10th -> analog -> DSP board (ADC -> DSP -> DAC) -> amps so I thought removing the extra ADC/DAC would help. I connected a pi running Moode to the DSP board via i2s and while it helped some, there is still some hiss. I was looking at the miniDSP nanoDIGI, but they're are no longer being made.
Have you tried a simple filter or no filter at all for the tweeter, maybe it's not the amp or other equipement but just the filter in dsp. I had some issues with the sound while using dsp and when i re-write the same dsp filters on the chip it got away.
The cheapest miniDSP uses a similar ADAU chip to the DSPB-K which is essentially what I'm currently using but also has opamps on the outputs. The amp powering the tweeter is an Icepower 125asx2 which has a CMoy preamp after the volume pot. I'm looking to utilize a 50asx2SE without preamp or volume in the near future and we'll see if this helps. I have made some changes to the filters, but your suggestion is a good one.
Originally posted by silverD View PostTom, I'd have to pull up the WinISD model on other computer, but I think at 70W/100dB both the woofer and PR (with 30g mass added) are under xmax with a HPF at 20Hz.Originally posted by tomzarbo View PostI'm so sorry, I modeled the PR with an older Esoteric woofer, not the Epique 5 1/2" sub, my mistake!
SilverD - Now that you've had some more time to listen to these, did you make any more tweaks? Regardless of tweeter, any reservations on recommending the E150HE for small two-way builds?
