The LPS-R2/JR
  • #31
    OK, these are getting cooler and cooler!
    • #32
      This cloth is very loose weave. I was thinking hot glue but now I'm thinking Titebond so I can adjust the weave to straight. Maybe some more thinking is in order. Maybe starch and ironing.
      Click image for larger version  Name:	IMG_0001 (11).jpg Views:	0 Size:	595.0 KB ID:	1490940
      • djg
        djg commented
        Editing a comment
        Titebond is useless on this polyester cloth, it won't soak in. FYI
    • #33
      And definitely paint the frames black.
      • Steve Lee
        Steve Lee commented
        Editing a comment
        Looks like cheese cloth . . .
      • djg
        djg commented
        Editing a comment
        Well I do live behind the Cheddar Curtain.
      • unclejunebug
        unclejunebug commented
        Editing a comment
        Personally, I wouldn't mind living behind a Gouda Curtain but that's just me :D.
        Do these just press fit into the cabinet to install? Really like the look of that veneer, what did you finish it with? I have some Walnut I'll be using for sub enclosure here, hopefully sooner than later.
    • #34
      Sticky back velcro for the grill retention, finish is equal parts Minwax wipe on Poly, linseed oil and mineral spirits. You can get some shine with enough coats, this is fairly flat.
      • #35
        If you staple the cloth you will be able to remove some and tighten the cloth if it sags(or replace if damaged).
        • #36
          So, I asked the grille clothe vendor how to best mount the cloth. He said make some long clamps to keep the weave straight and use 3M spray adhesive. That seemed a bit messy.
          I remembered the floor tile mount tape I have used to bond mdf layers on some projects. It is very aggressive and neater than spray.
          A sample grips the light cloth tenaciously to wood, so I will try that. Along with the clamping suggestion to keep the cloth straight. The stuff is really like cheesecloth, as Mr. Lee noted.
          Quite a project. I will illustrate in the next few days.
          • #37
            So I used the tape which works great. The job on the whole is a PITA. I taped one cloth edge to the counter, clamped the frame down over the cloth with a 2x2, taped the cloth free edge to a piece of 1/2" mdf, and stretched it over and stuck it down. One down, second one should be faster as I have worked out a method. The main obstacle is the loose weave of the grille cloth.
            • #38
              That really is coming out well - I'll have to remember your process.
              It's frustrating not having 4 hands sometimes . . .
              • djg
                djg commented
                Editing a comment
                I'll take a picture of the setup tomorrow when I do the second one.
              • Steve Lee
                Steve Lee commented
                Editing a comment
                Please, Do.
                I have a retrofit project I'll need to make covers/grilles for this winter . . .
            • #39
              Grille. Tape one side to the counter and the other side to a board. The clear packing tape adhesive is strong in shear but comes off easy.
ID:	1491164 Click image for larger version
              • Steve Lee
                Steve Lee commented
                Editing a comment
                ^ Looks simple enough - thanks.
            • #40
              Done. I think they look like the Dynacos, a blast from the past.
              Click image for larger version  Name:	IMG_0005 (1).jpg Views:	0 Size:	603.3 KB ID:	1491167 Click image for larger version  Name:	IMG_0006 (1).jpg Views:	0 Size:	551.5 KB ID:	1491168 Click image for larger version  Name:	IMG_0007 (1).jpg Views:	0 Size:	568.7 KB ID:	1491169 Click image for larger version
ID:	1491170 originals
              • djg
                djg commented
                Editing a comment
                Thank you.
              • blue934
                blue934 commented
                Editing a comment
                Drool!
                That's some serious retro sexiness right there. Great job.
              • djg
                djg commented
                Editing a comment
                Thank you.
            • #41
              Hard to tell the difference other than the smoky room patina of the originals - nice job on another fine set of speakers.
              • djg
                djg commented
                Editing a comment
                Pot and patchouli. Thank you.
            • #42
              Wow, those are excellent!!
              • djg
                djg commented
                Editing a comment
                Thank you.
            • #43
              Finally I'm making stands like these from stained pine.
ID:	1491181 Click image for larger version
              • #44
                Nearfield. The contemporary Trimline phone.
                Click image for larger version  Name:	IMG_0001 (6).jpg Views:	29 Size:	525.5 KB ID:	1491185 Click image for larger version  Name:	IMG_0001 (8).jpg Views:	0 Size:	595.8 KB ID:	1491229
                • silverD
                  silverD commented
                  Editing a comment
                  You should start using the tiny floor jack and mini solo cup in your build pics for scale!
                • djg
                  djg commented
                  Editing a comment
                  I thought about it.
              • #45
                Stand pieces.
