Hello Tech Talk!
I built these speakers during the week between Christmas and New Years 2021. I wanted to do something interesting for our office. I saw this project "pine" board at lowes made from pine boards of various length all glued on edge and thought it looked really cool. It inspired a new speaker build.
Design Goals:
Driver Selection
To keep weight low I wanted to use all neo-motor drivers.
Woofer: Tang Band W5 W5-1138SM
I was originally planning to use all ND series drivers but the simulations just weren't panning out as well with ND140's in a small box. I'm sure I could have hammered something out with the ND140's and it would have sounded fine, but the W5's characteristics produce a better looking transfer function in a tiny box.
Midrange: Dayton Audio ND91-4
I tinkered with simulations on the intended baffle width with lots of different placement of ND64/65/90/91 series drivers and landed on this as a good compromise. I was actually hoping to use the ND64-4 for this project but I wasn't happy with the way the response was turning out with it on baffle and with filter components in-play. I'm sure I could have "hammered" it into submission with more filter components but the way the ND91 was simulating just looked a lot better on paper with fewer parts thrown at the problem. I also liked the fact that this driver claims to have had special attention payed to making a very low distortion motor. Indeed they do sound very "easy on the ears" in my opinion, even when driven hard/loud, suggesting a low distortion performance.
Tweeter: Dayton Audio ND16FA-4
I just wanted something small to pick up the top couple octaves that would be easy to install close to the midrange driver. After reading about a lot of different little neo-motor tweeters all indications are that for crossover points above 4K these offer phenomenally low distortion for a dirt-cheap light weight driver. The even smaller flange ND16FA-6 would have also probably worked well for this but I felt like the larger flange of this driver would be more forgiving to install.
Simulations / Crossover Design:
I have taken a liking to "SpeakerSim" as of late. It has some quirks and bugs, but is easy for me to use. I used PE published data for the ND series drivers and a tracing tool to generate frd/zma data for the W5.
This is what I came up with after lots of tinkering and hammering and compromising. It's not a perfect result but it's a usable starting point. Crossover points are approximately 570hz and 7700hz. The "component detail" windows are overlayed here to show that there's also a 3ohm and 2ohm resistor in the band-bass circuit at critical locations to "shape" the response.
The woofer circuit uses electrolytics and iron cores to keep cost/weight down. The cap values purchased are 100uF and 125uF. The "10% tolerance" on these cheap caps almost always errs on the side of what would cost less to manufacture so the simulation is done with 90uF and 115uF responsively to give a more realistic representation of what to expect.
I will probably experiment with lower crossover points between the W5 and ND91 in the future. As I recall, many of the higher value inductors and capacitors I was going to need to pull down the crossover point were back-ordered at the time I was ordering parts for this build, so I was sort of simulating "around" what was actually available from PE. I prefer to do business with PE for this stuff when I can, I've been ordering stuff from them for occasional speaker projects since I was a teenager, (over 20 years) so there's a nostalgia factor here. They also tend to have good prices but this build really wasn't intended to be cost efficient, just elegant where possible.
The dip at ~150hz is the "bottom" of the valley created by baffle step loss intersecting falling room boundary reinforcement. The dip causes the speakers to sound slightly "thin." EQ helps. If I revise the crossover I intend to pull the crossover point down to around 200-300hz, which will give some tweaking leverage against that dip.
The dip at ~2500hz is an uncorrected baffle diffraction issue. My ears aren't sensitive enough to be able to care in this range.
Minimum Impedance is about 3.6ohm @ 84hz. One of the challenges when trying to hammer a response flat is to do so without inadvertently causing a ton of electrical phase shift or deep kinks in the impedance. The ND91 was easier to work with in this regard as a mid-range than other ND series drivers I experimented with in simulation.
Box is about (woops not 14) 7 liters of remaining volume tuned to around (woops not 28hz) 35hz. These require solid floor/ceiling/wall boundary reinforcement to counteract the falling response below 60hz and a touch of bass boost also helps. These are intended to be placed close to a wall, not out in the room like some speakers. Unfortunately, the predicted boundary reinforcement in the office was way off. More on this later, but in short, a drop-ceiling is not a boundary for bass! The bass extension in the office is lost due to a number of factors (the room shape is terrible and the ceiling is acoustically transparent at low frequency)
The sim below is wrong... I'm not sure why my sim file had 14 liters saved in it, maybe I was planning a revision floor standing version of this or something?
Baffle step/diffraction is accounted for in SpeakerSim.... This is just a "combined" baffle response example, but each driver has its own simulation based on the position on the baffle. The ND91 and ND16 drivers were pushed off-center to combat that baffle diffraction peaking response around 1-1.5khz.
The simulated listening position for this speaker is actually in front of the Woofer. This may seem odd, and normally, this would be the WRONG way to do this type of simulation, but I knew I was going to be mounting these up HIGH on the office wall. Our listening position is actually almost always BELOW the speakers. Even when standing in the middle of the room with the speakers tilted down a bit I'm still looking basically "at" the woofer as my listening position. The mid/tweeter drivers are above my head when standing.
Continued....
Design Goals:
- Build my first 3-way speaker.
- Try to do a "wide-band-ish" midrange so that most of the mid and treble comes from a "point-source."
- Light weight, reasonably small so it can be wall mounted with dry-wall anchors in an office without tearing down the wall.
- Good looking! Conversation piece.
- Easy to finish! I don't want to spend days sanding and applying coats of varnish or stain or paint only to be disappointed by the result.
- Deep bass extension.
- Low to moderate output levels, low sensitivity is fine for this intended use.
- I guess they should sound good and have reasonably low distortion? hehe...
- Select components that are actually in-stock! (this isn't always easy!)
Driver Selection
Continued....
