My (in progress) project *pics too*
  • #61
    Re: My (in progress) project *pics too*
    • #62
      It's looking great. I see the body filler came to the rescue again. I went back to my auto paint dealer and bought a gallon of the Evercoat Rage Gold. Fortunately, it was on sale. I can't wait to use it -- it sure looks like it worked well on your project..
      Tritrix HT:http://techtalk.parts-express.com/sh...d.php?t=222519
      Dayton 12" Subwoofer: http://techtalk.parts-express.com/sh...d.php?t=222930
      Overnight Sensations: http://techtalk.parts-express.com/sh...d.php?t=223751
      Cerberus sub: http://techtalk.parts-express.com/sh...hlight=cerebus
      Duellatis: http://techtalk.parts-express.com/sh...d.php?t=224943
      NTN's: http://techtalk.parts-express.com/sh...d.php?t=227902
      • #63
        Yeah, you'll be glad you did. Its great stuff. You can see how well it worked for me in getting crisp lines on those repaired edges. Apply, then sand with a little 80 grit, followed by 120 and its good to go
        • #64
          Sad to report...but more issues. So when I did the driver recesses for the Usher 8955a's, I didnt get a clean round cutout, and the recesses were too deep. When I initially test fitted I figured it was something I could live with, but after looking again now that the baffles are mounted...nope :(
          I thought about it for a bit and came up with a neat way to fix it.
          So...the solution? I used some veneer edge banding I had laying around and applied it to the inside cutout. I then cut some 3/4" pieces of drinking straw out and screwed the fasteners in enough to hold them in place. The reason for this was to prevent the filler from getting in the existing holes I had prepped for mounting. After that, it was on to filling the 'trenches' with some rage gold. Definitely a sloppy application, but what can you do...
          I just had to be careful not to slop up the veneer I already applied.
          Some pics of the prep and some pics coming soon with the result. My plan at this point is to just get a clean edge all the way to the driver cutout diameter and just surface mount them. Theres no reason why I really need to flush them in anyways, so that was the decision.
          • #65
            Very inventive!
            My Home Theater Build thread
            My DIY Speaker builds
            My Gear:
            Emotiva XMC-1
            Emotiva XPR-2
            Emotiva XPA-5
            Clearwave Dynamics 4T and 4CC (mains)
            Paradigm Millennia LP (surrounds)
            Oppo 103D
            Mede8er 600X3D w/ 4TB
            Marantz CD-5004
            AppleTV
            JVC RS-4910 Projector
            100" Screen Innovations Pure Gray Screen w/ LED kit
            APC Uninterrupted Power Supply (x2)
            iRule controlling it all....
            • #66
              Wow, at least you hadn't veneered it already!
              रेतुर्न तो थे स्रोत
              return to the source
              leviathan system thread
              deadhorse thread
              shockwave build thread
              instagram :: greywarden_13
              • #67
                I guess a nice, thick, cork gasket was out of the question?
                • #68
                  I am assuming that you used circle jig for the cut outs? You can make round filler with the same jig or even use the jig to make circle template and just re-cut to the depth.
                  http://www.diy-ny.com/
                  • #69
                    Well, the only issue with that is that I'd still have a gap around the edge of the driver :o
                    I never thought about cork for a gasket though...thats a great idea.
                    • #70
                      You know, I thought about this but I had several problems with doing it that way. First, I'd have to get the thickness of the filler piece right, and second...it wasnt a perfectly round cut as I had a little hiccup here and there on the cut for the recesses (router motor decided to start dying) so Id still have to use liquid filler for the little gaps :(
                      Pics coming shortly of the reworked areas which are now sanded...Just need my camera battery to charge a bit.
                      • #71
                        And here's the result...Pretty smooth and ready for veneer and drivers!
                        • #72
                          So the drivers are now going to be surface mounted instead of flush mounted?
                          Craig
                          I drive way too fast to worry about cholesterol.
                          • #73
                            You got it. Keep in mind though that these are just the woofers in the bass cabinet section. The MTM drivers are still recessed.
                            • #74
                              sucks mang! glad it will work out for you though.
                              • #75
                                What would a spiral bit do to that filler(I have no experience with it)? Here is a thought. Why do you put veneer on now then drill your center pilot hole in the veneer and just try the recess again with a 1/4" bit then move inward to complete the recess. This all would depend on the fillers ability to stand up to the router bit.
                                Also, why do people cut holes before they veneer? I find it much easier to cut the recess and mounting hole after veneer is on. Tear out is not really an issue with any decent bit.
                                Chris
                                Chris
                                Goofing around since 2000.
