New SuB build
  • New SuB build
    It's not ausual wood working thread ... more connected to car audio ...
    but still wanted to how it here :D
    the box is 25L the port is 23cm long
    for 2 x 6.5" woofers
    Re: New SuB build
    more
      Re: New SuB build
      Looks like you've got a good start. Anytime you set it up right at the beginning sure helps it go easy towards the finish.
      Are you going to bondo the fold smooth?
        Re: New SuB build
        I like the way you supported the driver rings - much better than dowels like I did. The one issue the dowels did help with is how the fabric when stretched sucks in reducing internal volume as can be see on your box.
        Brad
        piano black sealing mdf irregular recesses grill technique
          Re: New SuB build
          Fiberglass coat .. -> bondo -> sanding -> bondo .... SANDING ..
            Re: New SuB build
            Bondo -> sanding -> bondo -> sanding ... ( took me 3 days ) may be nex time I'll perchuse a cordless sander ... :D
              Re: New SuB build
              Primer and color
                Re: New SuB build
                You guys have me excited to get back into car audio, next year perhaps I will do something along those lines.
