I started this project last September and have been enjoying for a couple weeks now. This is in my '77 VW Bus.
After discovering that the doors are fully vented at the front by 6 1" x 2" oval holes and that on the freeway the plastic door panel cover/seal gets sucked out very tightly, I figured that I needed to isolate any drivers from the inner door air space and some sealed enclosures were in order. I first demo'd a few 7" drivers in a 5L enclosure and the RS180-4 won. I knew that the R180 would be best as a 3-way - so I needed a mid. I went with the Morel MDM55 for the mid because it's sealed and has a small faceplate and motor. The tweeter is the Vifa DX19. I'd go active, but a 55-amp alternator won't allow. I have an Alpine MRD-F752 Tripath to help with current draw.
I've never fiberglassed before. It isn't tough, but some experience certainly helps. Spray glue and fiberglass is a joke - a staple gun is best to secure the fabric, but the glue is handy to get it stretched in place. Using chopped mat strands mixed in with the resin is the best way to fill tight corners. I made my own strands by just cutting the chopped mat since I didn't need a ton. The Knytex mat is nice, but not necessary.
I figure that I ended up with about 10 liters of air space.
