Challenger - 8" silver flute / SB waveguide
  • #16
    Re: Challenger - 8" silver flute / SB waveguide
    Ok, I decided in the end this could be improved. And I was able to improve it.
    Still haven't made it outside for some real good measurements. But here is one at 1.5m:
    This thing really needs to be measured at 2m. Then it'll be even flatter.
    The xo (even though the null doesn't indicate it) is now at 950hz and there is more BSC.
    And look how cheap this cross over is
    https://www.youtube.com/channel/UCm2...oSKdB448TTVEnQ
    • #17
      Is that enough to protect that tweeter down that low? It seems to me that it may need a bit more and you may need to tame the rising response at the top end as well.
      • #18
        Yup, it's well protected. That's part of why I originally went with 1500hz xo, but after I ran compression testing, I realized this thing can take it. I did 128watts with a single 5.9uF cap and it didn't flinch. So with 4.7uF it should be even safer.
        The top end doesn't bother me at all. It's 4 or 5db hot, but I can't hear it way up there. My db scale is much more course than a lot of people show ;)
        The whole response smooths out at 15 degrees big time. Gotta get outside and measure at 2m. Then the null will move into position and I can get a polar response.
        • #19
          Oh ya, and I measured the 2.83V SPL using REW and the FR hovered right around 93 or 94db at 1m!! That's into a 4ohm load though. Well, 4.5ohm :o :D
          • #20
            This is a really cool build!
            Are there any other designs like this, but in a 1.2 cu.ft. vented enclosure, tuned down more around 40-60hz?
            • #21
              You could just do it in a tower or something. I did this before the SEOS was available. I think the SEOS builds are better, but they're also 14.5" wide. If you need narrow, there are a few 8" ones. This one isn't bad, but it does have vertical issues. It's a 1000hz cross over, so not bad.
              • #22
                I love the look , great build!
                • #23
                  Ryan, I had a bit of fun with the SF's 6.5 and 8" . (Pic)
                  Hey question, what's the volume of the double 8" box?
                  btw, I might have to try your project next - have the parts (if that's a SB29).
                  • #24
                    btw, this fellow was nice enough to help with the xo, info here:
                    I may have the parts to build the wave guide, did you use the 8ohm SF version?
                    • #25
                      Hey HiFy Guy.
                      I think I used 25L for both. They were the 8ohm.
                      You can get the waveguide from PE. It's the HW08 or something like that. Just mill the threaded throat off and open it up to the diameter of the tweeter diaphram and surround. Really improves that tweeter.
                      I sorta wish I finished this design. I went 95% of the way, just never really did any final measurements.
                      Enjoy your new speakers!
                      • #26
                        That's about double the size of the vented box in the middle post #23 pic, probably sound about the same since the woofers don't push a much air, not much cone movement at all. I got word that they can work in 1.5cf each - 3cf total.
                        Let me know if you get curious about the 6.5", 8ohm version, that's one crazy little woofer! I have a few xo designs, they all sound wonderful.
                        Thanks for the HW08 link, will order a pair soon. This must be it: http://www.parts-express.com/pe/show...number=270-308
                        • #27
                          These commercial speakers use the same units and claiming some crazy bass extension figures, what cabinet design are they using ?
                          quote
                          "Without revealing too much secret information, Vflex is a twist on the ‘ole bass reflex design. While the tweeter is sealed, the rest of the tower is a ported design, but the bass is loaded in a rather different way.
                          Mr. Gaboury is careful not to reveal all his secrets, but I managed to extract this from him; “In a reflex enclosure, the air inside the enclosure doesn't move much, and the cone acts on the trapped air mass, and that mass releases its energy through the vent, like a spring or sling shot, and the tuning or loading is typically calculated to match the resonance of the system, which is the point where little energy is needed to create movement. It's really a matter of mass because the cone is loaded on a narrow band. In the Vflex, we add to the mass a force factor. The air mass is put in movement through acceleration and deceleration, generating force along the chain, where each link is a spring, accumulating and releasing energy on yet another spring. This succession of springs moves the air inside the enclosure with high torque. Each high pressure zone is balanced with a low pressure zone somewhere else in the system, and pressure is always moving from one end to the other, in perfect synch with the loaded cone, and the springs system keeps the woofer loaded on three octaves"
                          • #28
                            A speaker bud sent me that link the other day. I didn't have much luck with vifa XT combo, it was flat enough, just didn't like the middle.
                            I couldn't begin to explain how the SF works, I know the it's a little different than most mid woofers - springy with a big magnet.
