This is my latest build and was my entry in the MWAF 2012. It's an OB/H-frame inspired by the Linkwitz Orions, but done entirely with passive components. The tweeter is an LCY-110 which has its face plate removed, I milled the opening in the baffle, and mounted it directly to the baffle. This allowed me to get the mid and tweeter closer together and helped time align the two. The baffle is 10 guage 5052 aluminum plate with woven Carbon Fiber/Copper laminated on the front and Cascade VB-2 Damping on the back. The midrange is an Audax Areogel HM130Z0, and the woofers are Audax Aerogel HM210Z12's. The bases are made of 1" thick Walnut butcherblock countertop. The internal woofer baffles are 3/4" MDF. Crossover duties are 12dB @ 90Hz low pass on the woofers, 6dB @ 150Hz high pass to the mids, then a serial crossover based on the Acoustic Reality platform between the mid and tweeter (6dB @ 2500Hz). This design employs no capacitors in it yielding no phase shift at the crossover point.
