I just completed this project a few days ago (sorry for not posting a build thread). This project is for my mom for her office computer. I have been obtaining all of the components needed for this build for a few years now it seems, and just decided to build everything. The PC speakers are a bit modified from Ben's original dimensions, purely for aesthetic reasons. They maintain very closely to his spec'd volume, and have a removable baffle that is made from solid pine. I remember seeing a few builds of people mounting the dayton ND series on the back of the baffle to hide the frame, so I stole that idea and did it with the ns3's. The opening has a round over on it, and all edges were chamfered. I contemplated doing round overs, but I had a picture in my head of how I wanted the subwoofer to look so I stuck with the 45's. The paint is just a basic gloss latex with a clear coat. It's much easier to build then it is to finish for sure!! They are being powered by a Lepai 2020A.
The triska subwoofer was built to the dimensions that Shawn had spec'd. I did add a vertical brace to connect the top and bottom panels, but that was it for bracing. I did use the sa70 for power, and it is more then enough. I picked up the SD215 when PE closed out the shielded versions for a good price. It, the PR's, and the sa70 are surface mounted. I had also bought three grills to protect the goods but they ended up not fitting
so I will have to think of something else. Personally, I am not a fan of speaker grills but the subwoofer will reside in a place that my niece is active in and do not want them to get damaged. It has the same white paint, with chamfers running vertical on the four corners. I cut a bottom and top piece made out of pine that extends all edges by about 1", and each corner is 45 cut to match the box. I think it turned out pretty good, and they are just attached using brad nails. All the pine wood was finished with danish oil.
Here are some pics
Here are some pics
