Before I present the Flinstone end/coffee table sub design I have to say I dont have woodworking ability and very few tools...so I decided to build this sub based on the little ability and 4 or 5 tools I have. Good thing is the sub goes tucked in between the corner wall and a sofa so details and posible flaws wont be that visible. Also the wife likes rustic stuff.
I was given a couple of Technics 2way speakers that I decided to siamese for this project. Will use the original 10 inch woofers which are in good shape and sound pretty good; aimed at about 6 inches from the the floor. Ports are 1 7/8" I.D. and 2.5 inches long. Havent decided yet if going sealed or ported. Overall table size is 17" high and 27.5 x 28.5 on the top.
Going to use a 120hz 2nd order passive crossover on each woof powered by 50 watt each channel...or maybe a 4ohm plate amp(80 watts) and wire woofs in parallel. Has 100 or 120 hz selectable xover, level and phase control. Will decide on that later.
The legs and top of table are made out of 2" x 6" wood(pine, I think) since I have a miter saw. Easy to cut and work with. I mocked the box up fastened with 2 1/2 inch wood screws just to see the fit and how it looks. Will dismantle, sand and glue everything up and retighten with screws. Screw holes will be filled with wood filler, then resanded and finished with Varathane wood tint(color Gunstock) which matches well with existing component table.
So here are a couple of pics of the Flinstone end table sub progress. Any comments or suggestions are welcome!
