Due to family commitments I have not been working in the shop much this winter. About 3 weeks ago I did start my OS Center Channel to match the OS MTMs I built last year. Without the need to provide a flat surface to mount ports the CC was designed as an ~1/2 ellipse.
The shape lends itself to layered 1/8 inch poplar plywood, except for the tightest part of the ellipse. Bending 1/8 inch ply resulted in breakage at the center line of the cabinet back. Neither kerf cut MDF nor skateboard maple veneers were able to make the bend. My solution was to build this section with strips of poplar ply. Staples were used to hold the strips in place until the glue dried. Staples were pulled with a pair of pliers after the glue had cured. The last layer was sanded and smoothed with Bondo. The following pictures show the strips and tweeter x-over as well as 3/8 inch dowel used to align the braces. The low pass is mounted on the other side of the center brace.
The veneers are Wenge for the cabinet and Imbuya for the baffle. Currently I am waiting for the baffle to cabinet glue to dry before installing drivers. The last step is to build a 4 leg stand from Wenge so that the speaker can be angled up or down depending on listener height.
My thanks to Paul Carmody for another OS design and to the folks at PE for hosting Tech Talk.
