If you have an immediate customer service issue, please visit us at Parts Express
I don't know what project you are referring to.
"Wolf, you shall now be known as "King of the Zip ties." -Pete00t "Wolf and speakers equivalent to Picasso and 'Blue'" -dantheman "He is a true ambassador for this forum and speaker DIY in general." -Ed Froste "We're all in this together, so keep your stick on the ice!" - Red Green aka Steve Smith
Still making these....and wish I thought about this years ago.
Made 4 of these 5" woofer mtm's, all low budget projects; had a dozen of Peerless 5" woofers and several Vifa xt25 in storage/boxes.
Found specs on the old drivers and ran in WinISD; an advanced forum member designed the xo.
The pair on the left was a two day project, started with 16" mdf shelving board; one of the best, easiest products to work with. Hands down - much better than the dark color mdf.
The paint is two coats OIL, one primer (4 hr dry) and one top, which set overnight.
The bass here is simply 5 stars!!! And just what I was looking for. May look into other 5" woofers, mtm's of course ;)
Still making the mtm's - this is about 1/2 of them ;)
I guess some don't like the complications of a mtm, but I'm really liking what they have to offer.
I wouldn't recommend them unless you can get them up to ear level, or point/angle the bases to the listener.
Made some updates here......
A buddy came up with this -tried it/liked it.
Removed dust caps off the 6.5" 8 ohm SF woofers and made mdf phase plugs.
The dust caps came off pretty easy and saved them in case I want to put them back on (plug may bump cap, don't know)
Picked up 3" SS bolts at HD and bolted the plugs right thru magnet, made cork washers so no vibration/noise, etc.
Results - highly recommend this for SF's; as they have a deep voice coil, 7/8" of exposed alum. coil.
There is less breakup, which is noticeably better. Movie dialogue outstanding, the HT never sounded better!
SF's are surprising well built, with imbedded factory gaskets; now the midrange is clearer and think this is a way to take a low cost woofer ($29 each) and enhance it with a couple of hours of work.
I have to say great looking MTM's! Can you give some more info on the finishing process?
What kind of oil base paint? How do you apply it? I'm in the middle of a MTM build, going
piano black on them. Doing the flat raddle can spray with spray poly over it approach. First time
using this technique.
I really don't have much patient for sanding/painting - one day is about it.
Post 57 may only have 2 coats (one primer - one finish) some of them have 3 coats.
The ploy here is the MDF is going to move around, so get them looking pretty good, wait a year, re-sand and give them a final coat.
They still sell oil at box stores/hardware stores; look for oil base primers also, they are easy to find and don't cost a lot. I'll take oil primer over water base anyday! Mineral Spirits can be found for $7 a gal.
No spay booth and work outside so I run the pressure up to 50psi, wide fan & spray fast, as soon as the surface is glossy wet - stop!
A fan nearby is also a good trick, keeps insects off, helps to dry obviously.
Make up a spin table with 2 boards/nails, etc. stay in one place, move piece instead.
So took a little break for a while but back at it.
This is a vertical Ansonica build, very, very quick but solid with plenty of reinforcing.
(36" high and 70 lbs each). Used the parallel xo.
Only had them up and running for a week or so, but enjoying them; highlights: lots of detail, imaging and extended low bass.
No paint, I'm not going out in the garage anytime soon.
