Hello everyone.
I wanted to post the pictures and describe the adventure of assembling my overnight sensation knock down kit. (disclaimer
) I have pretty much zero experience with woodworking.
After I completed assembly of the kit (Which was very easy and straight forward) I wanted to apply stain. I block sanded the wood out to 400 grit and I applied minwax ebony stain. Even though I followed the instructions, it seems that I messed something up during the stain application; the stain didn't darken the wood as much as I would have liked and it turned out blotchy. After a 2nd application of stain I was happier with the color, but it was still blotchy. I decided to apply a 3rd coat of stain. I didn't wait long enough between coats and the 2nd coat started to lift when I was brushing on the 3rd coat on.
At that point I was getting frustrated. So I decided to start over, I used a 120 and a 220 grit pad on a DA sander and went to work. I completely stripped the wood and started from scratch. I re-stained them both, this time I was considerably happier with the results. They both have a little uneven color and blotches in spots; I decided it was good enough so I let the stain cure for about a week, in the meantime I was reading up on finishing the wood. I made bit of an uninformed decision. I decided to spray on some PPG Acrylic Urethane clear. I sprayed on 3 coats; the cleat didn’t lift or have any adverse reaction with the wood/stain, I’m very thankful for that. It's not as smooth as I'd like, but decent enough.
I went over them with some hand glaze and finished the assembly. I plan on buffing and adding wax after they cure for about a month. I didn’t think to take pictures of the crossovers or the internals. It’s nothing outstanding at any rate, just the components laid out on a piece of peg board.
On to the pictures
On to the pictures
