The Speedster Towers--A MLTL version True to the Originals
  • #16
    Re: The Speedster Towers--A MLTL version True to the Originals
    For this design the length of the line was selected to optimize the bass output and to place the tweeters at the best height for listeners. Paul covered the relationship between the woofer and the port locations and why they become important for this design.
    These speakers work best when floor standing. But if Panda wishes to flip one speaker upside down and place it on his desk, it should function OK. I should add that you should not change the baffle layout but physically flip the whole box. As he suggests, the tweeters would be located at the same height. As built, the woofers cover the listener with good sound in a close listening situation. If your furniture placement changes, you can change the speaker orientation for your new situation.
    • #17
      Very nice design. The tower is so slim, it is hard to believe that it can go that low.
      Could it fit in a PVC tube of say 4inch? That would be a very futuristic look, especially in clear!
      Well done, the thought is simple but very effective. I always prefer floorstanders over bookshelf speakers, simply because I don't have a shelf to put them on. Besides, everyone needs some bass in their music.
      • #18
        nrg74,
        As I stated in the first message in this thread the inside dimensions are 5 x 4.5 inches so the area is about 22.5 sq. inches. A round tube 4 inches in diameter would yield about 12.6 sq. inches so the cross sectional area is significantly less. My gut feeling is that the CSA reduction will be too much to work as I originally designed.
        I'm on travel and away from my computer on which I have the Martin King MLTL worksheets for a few days so I can not give you a detailed answer until later in the week. Also the W4-1720 driver is more like a 5 inch frame size so I suspect that it would not fit 4 inch PVC adequately. If you have alternatives (larger pipe diameter, perhaps a larger pipe diameter with a half section, etc. which could be considered. Let me know if you have options that I can run when I return. The issue also becomes a crossover problem if we deviate much from Paul's 6 inches wide enclosure as well. Let me hear what flexibility you have.
        Jim
        • #19
          How did you retain the stuffing in the top half of the speaker? I've gathered that one wants to be careful to not change the cross sectional area too much with braces.
          • #20
            I use a piece of wire fencing (small mesh) wedged in the enclosure just below the woofer to retain the stuffing in the upper 1/3rd of the enclosure.
            You likely would not need much, if any, bracing with this design as the internal dimensions are small. Five inches is the largest width or depth. Combine that with the wall thickness of 3/4" (18mm) and you have a rigid structure that needs little additional bracing.
            • #21
              Jim, Question regarding the baffle width.....you state " The width of this speaker is 6.5 inches vs. 6 inches for the bookshelf version which will slightly impact the baffle step correction"...........The dimension of your design is 6.5"Wide and 6" Deep.......why wouldn't you make the 6.0" side the front baffle and maintain the correct baffle step correction.....I not sure if this would change anything, maybe the design of the slot port. Using a round port would fit on a 6 inch baffle. Just curious.............
              Thanks BobC
              • #22
                Bob,
                I used 0.75" thick walls (6.5" wide baffle) for my Towers vs. the 0.50" thickness of the original bookshelf units (6" wide baffle). I wanted the construction of the Towers to be more rigid than normally used for the bookshelf design. The extra wall thickness does have a slight impact on BSC but not enough to necessitate a change.
                Now as you mentioned you can use flip the baffle to the 6" side of the box but I would caution that this may slightly intrude on the available air space around the rear basket of the woofer.
                In fact Paul Carmody has addressed this baffle width question before and has stated that he did not think that it would significantly impact the performance of the speaker. Paul has said that the crossover will still work the same. See his comments on the first page of the MMT design write-up at:
                https://sites.google.com/site/undefi.../speedster-tmm
                You can use either the slot port or round port option in your build. I used a slot port that exits the front of the box for my prototypes but you can arrange for the port to emerge from either the front or rear of your enclosure.
                Let me hear if you have additional questions.
                Jim
                • #23
                  Question for Jim or anyone who might be able to answer this. I am going to build these MLTL towers and had a couple of questions. One, do I use the crossover layout for the original Speedster TMM that was done by Paul (minus) the extra resister for the second woofer? (Does any one have a layout diagram of this crossover showing where what part goes where?) I am new to this and the crossover schematic is hard for me to understand. And second, Is there a matching center channel for these? I don't really have any size restraints so I was hoping for a plan that used the Fountek tweeter, Tang Band mid/woofers and 6 or 8" woofer. Thanks
                  • #24
                    Trevor,
                    My Speedster MLTL uses Paul C's original crossover for the bookshelf speaker design. See the diagram at:
                    https://sites.google.com/site/undefinition/speedster
                    I don't have a photo of my crossover for the prototype build but you may find other Speedster builds with a crossover layout. Often in a small MLTL I will separate the woofer and the tweeter crossover networks and build the two networks on smaller boards. I place the tweeter board in the upper part of the cabinet while the woofer network is located behind the terminal plate near the bottom of the box. Wire from the terminal plate to both networks as evident in the crossover schematic.
                    I don't know of a specific center channel version of this speaker. If you have the vertical room (and don't mind the look), you could use a bookshelf Speedster box.
                    For another MT bookshelf application with a ribbon tweeter I laid the enclosure flat and rotated the tweeter 90 degrees. I suspect that this technique would work OK with the Speedster as the woofer and tweeter are closely spaced.
                    Jim
