(4) 2x 18" LMS Ultra 5400 in 15hz 27cube slot ported enclosure
  • #16
    Re: (4) 2x 18" LMS Ultra 5400 in 15hz 27cube slot ported enclosure
    Originally posted by Tin_Ears View Post
    Dang... and I thought my six IB 18's are gonna be overkill.
    They will be, and it will be fantastic.
    You like to play your movies a bit on the loud side?
    Awesome setup BTW. Scary, but awesome.
    I was hitting 115+ db in room at 20 Hz with my "Beast" setup using four ported 12" Titanics. I never could crank it up to where it gave out because my head felt like it was going to implode. Made the window on the gable end of the attic vibrate 1/2" each way during sweep testing. I turned it down after that. I can't imagine what your setup would do. Where is this at, basement?
    TomZ
    First floor of a high ranch, no basement due to proximity to the ocean. It currently hits over 130db at 20hz with ridiculously low THD. I hit the limits of my mics trying to measure it. With room gain, I get some monster levels at 10hz too. Problem is, between 15-20hz at high levels, excursion goes nuts. I've had the cones tap the spiders, though it was lightly, that's not good. That was my main motivation to do this build.
    Originally posted by saabracer23 View Post
    I'm excited to see the outcome of this over your previous setup. Your personal reaction that is. Most on this forum aren't accustomed to the ridiculously over the top systems like people on avs are.
    Dan
    Me too! I can't wait to get the rest built.
    Originally posted by ryanc View Post
    Good GOD!! My neighbor already complain about my crappy Polk PSW10 you know the $99 deal? My house shakes like a methhead on a withdraw with a sloppy 50 watts. I could not imagine that much power in my basement. It would crumble my foundation to dust!! I do like the set up though........I suppose I might need to reinforce the house because I got a woody seeing this one :D
    The walls flex pretty good. I built the first floor of this house with the idea in mind that there would be a ridiculous system in it at some point. In hindsight, I should have double-rocked it. The walls still flex a good deal. It's interesting that as I raise the levels I see some room modes disappear or shift frequencies.
    Originally posted by dstmbgh View Post
    I'm slack-jawed, not because of the SPL, but because of the $$L -- that's $7,400 worth of subwoofer drivers. Oh, my :eek:. Looks like quite a home theater setup. I hope your internal organs are as resilient as your wallet.
    I see now what you meant by the port being side-oriented -- you're using the side and much of the back for a front-ported slot-port. Looks like the tuning you achieved was extremely close to target. Did you come that close to target based on your initial calculations, and, if so, what K factor did you use. Seems like these often end up being tuned lower than calculated, I think because the K factor typically used is incorrect. Perhaps you adjusted port length after initial testing. At any rate, good job.
    Are the cabinets for these lined with any damping material, or are they left naked?
    I assume you built the rest of your setup (L, R, & C). Anything you can tell us about those?
    Welcome to the forum,
    David
    I used WinISD for calculating the port length. It doesn't give you much in the way of picking port ends, and since this is a slot port, there aren't really any common flares. It just uses 0.732. There was much discussion about the port before the build. Some were saying they say WinISD off by as much as 25%. I took the safe route and originally made the port 40" and left some space in the bracing so I could lengthen the port if necessary. With a 40" port the tune came in around 17hz. I added 15" and it dropped it to about 14.7hz. You can see a pic of the added port length here. Hard to tell exactly, but that's my best guess based on measurements and watching cone excursion. WinISD says it should be 55" for a 15hz tune and 57.6" for a 14.7hz tune, so it's quite close. If I flared the ends some or if it didn't have a 90' bend it might be more accurate. This box was built as an experiment, to see worst case what would happen. I didn't use any dampening material, I didn't round any port corners or flare any of the port ends. I will be hitting the ports in the front with a router just to make it look not so hideous. Pushing this loud enough to make everything in my garage sound like its going to fall off the walls and the ceiling flexing noticeably, there is no discernable port noise. Putting dampening material inside would affect tuning some, so I left it out as well. Any of the resonances it would help will be far enough out of the bandwidth that this will be used in. It seems the extra work doesn't really pay off, so that's fine by me.
    The LCR's are JBL pro cinema gear. 4722N's for the L/R, a 3677 for the C, and 8350s for the surrounds. At the prices and performance there, I couldn't convince myself to build.
    I have full info up at http://www.countercultured.net/pics/ht
    Just curious...
    i
    ...filter prevents over excursion below 7hz.
    How, i.e., from where, would they get anything below 7 Hz? No mocking or ridicule intended here; this is an honest question.
    Well, the filter is actually at 11hz, but you can see in the graph below that it flattens out the room gain some. By 7hz, it's -3db, then completely falls off. A bunch of movies have a good deal of content sometimes down to 3hz. 7hz is my -3db point, so I just tossed that number out there. War of the worlds, during the lightning and pod emergence scenes has some notoriously low frequencies. How to train your dragon as well. As you drop down to these super low frequencies, excursion skyrockets, so some protection is necessary when playback levels are high. Also, adding this in here, some recordings you'll find have subsonics from like, doors closing. I'll notice my drivers move at low frequency and it slams the door to the theater shut. Vinyl playback can be interesting as well. There's content there... but in the end, filters serve two purposes, protection, and taming the ridiculous room gain that made things sound/feel awkward whenever there was low content. Turning on an Xbox 360 for example sweeps upwards from very low, at least 10hz.
    This is post-eq with a little bit of bass boost. There's a room mode where I measured this at 80hz, I know I wonder if having these massive cabs in the corners now will affect my response any. I'll definitely be following up on that once I get everything completed and put in place.
    • #17
      Originally posted by nyt View Post
      ***Vinyl playback can be interesting as well. There's content there... ***
      Not sure "content" is the right word for the LF rumble from warped records. Actually encoded ULF on records results in extremely wide grooves. For instance, here's a shot of the Kunzel/Cincinnati Pops 1812 LP on Telarc.
      Cool setup though. Lowering excursion down low is a great way to protect expensive drivers that were designed with motors that can push the former until it's half mashed against the backplate...
      What about port resonances, though?
      "Based on my library and laboratory research, I have concluded, as have others, that the best measures of speaker quality are frequency response and dispersion pattern. I have not found any credible research showing that most of the differences we hear among loudspeakers cannot be explained by examining these two variables." -Alvin Foster, 22 BAS Speaker 2 (May, 1999)
      • #18
        Awesome image. I wasn't referring specifically to vinyl when I said there's content there, as generally, like you said, it's from warped records or needle drops in that case. In the case of the LMS drivers, the cone actually smashes into the spider before the backplate hits the former. Not pretty. Changes have been made to shorten the spider on some of the newer models I think... or at least that was planned. Either way, I don't have the newer models, so "only" about 40mm before damage on the inward stroke. At this point, the outward stroke is limited by the surround to a little over 30mm anyway, so I try to avoid pushing that hard at all anyway.
        Port resonance here appears to be at 109hz, where there's a sharp dip in output in my measurements. I took some other measurements back-to-back vs sealed when I wouldn't be bothering the neighbors as much, so I extended the frequency range a bit to capture this.
        vs selaed
        • #19
          Great build! I really envy your threater room and you having an easy going spouse. My lady would chop my nuts off if I brought anything that massive into the house.
          • #20
            heh my wife likes it, makes it easy
            • #21
              having your theater room ..going out to the movies must be a real let down
              • #22
                ^^^ Thinking of most commercial theaters I've been to the last 20+ years... it's not difficult or terribly pricey to build a HT that sounds and looks better. And if one goes to many movies... much cheaper in the long run. Of course, this is a king kong version HT so cost to build it might be just a bit higher than average.
                "We are just statistics, born to consume resources."
                ~Horace~, 65-8 BC
                • #23
                  Joeybutts will &^#% a brick when he sees this.
                  Your results may vary.
                  • #24
                    Hahahahha. I've seen his setup and some of the others on AVS. I definitely have a bit of envy. I think I met a good compromise of budget vs performance.
                    If I had
                    1. The space
                    2. The money
                    I would be all over this. It is definitely one of the top performing builds I have seen. Would love to experience it, along with MKtheater's setup and a few others on AVS.
                    Kick a$$ setup brother.
                    • #25
                      If I had
                      1. The space
                      2. The money
                      Hah thanks. Friggen AVS. I called out a troll in one of my threads and ended up getting banned over it. Some brain damaged mods over there.
                      • #26
                        Seriosuly?? Wow. I thought you were direct and forward with people, but never disrespectful or abrasive. Sorry to hear.
                        I can't wait to hear what you think of this change.
                        How have the Sanway's been holding up? I wanted to go with one (one would be enough for my measly setup :p) but couldn't bite the bullet on the risk.
                        • #27
                          Yep, they ended up removing like 50 posts of people bitching about it too.
                          Sanways been going good. I've been abusing the new enclosure with one out in the garage. Low frequency sine wave testing I'll get a vid linked later. Youtube kills the 60fps and re-encodes at 30 makes it look like crap.
                          • #28
                            Hello, IMAX!
                            Currently they use subwoofers built by Yorkville Sound with 4x LAB12 derived drivers.
                            Best Regards,
                            Rory Buszka
                            Product Manager, Dayton Audio
                            The best way to predict the future is to create it.
                            • #29
                              Originally posted by [email protected] View Post
                              Hello, IMAX!
                              imax... well... they have nice screens at least
                              • #30
                                I was wondering where you went!
                                On another note, I showed this thread to my lady said "Look what this guy's wife lets him get away with"..... Maybe she wont give me grief about the next build. :D
