Building these on a whim since I had the stuff laying around. Three way with two Goldsound 1044DVC 10" WOOFERS (4 ohm coils so will wire series parallel on two woofers for 4 ohm load), Klipsch 7 x 10" tractrix horn with D250X Selenium comp driver, and PE 4.5" elliptical horn/waveguide with EV 2442 comp driver (112db 1w/1m), and modified Klipsch Tangent crossover with autotransformer and resistor ladder padding on tweeter. 48.5"H x 13"W x 17" deep with cherry veneer and solid cherry corner trim pieces. 4" vent 13" long firing out of bottom.
It was a pain matching the veneer on the 45 degree sides. Next build will be with curved sides and one piece of veneer. Finally got it done as good as it was going to get and have started Minwax satin poly application. I'll build solid cherry feet to raise up 3" off floor to allow port to exhaust. A friend may buy them before I finish. Learned a lot of "what not to do building these". Will add grill frame as well
