After much deliberation weeks ago and help from many forum members (thanks again!) regarding my 5.1 HT/music build I've started on the OS MTM's. They'll first be used as my mains and move to surround duty after I build a trio of Sunflowers (L/R/C).
After all I've purchased, the folks at the local hardware stores know me pretty well by now. This build also sidetracked me for a little while - I started to make my own router table which has been fun. Waiting for the laminate to dry on the top as I type.
I've sketched them up just to help me plan the build and I've stumbled across something I want to run by everyone. I'm going to put the ports on the front because they'll be close to my wall. When I lay out the ports I need to move the MTM up the baffle by 1" to make room for the ports. In the attached picture I have them 0.75" from the inner walls and just under 0.5" from the base. I remember reading that ports should be at least 1" away from surrounding surfaces. The ports themselves are also very close to each other. Thoughts?
EDIT: I thought I'd add some more information to this thread about the tools/parts I purchased for anyone out there considering their first build. I know I spent quite a bit of time deliberating what I should buy and reading threads here about peoples experiences. I had an overseas move a few years ago and had to get rid of most of my tools, so I had to start almost from scratch. I purchased tools a little on the higher end of the price range as I'm planning on some renovations and wanted to make sure that they'd last. I was quite surprised that I bought most of my tools in retail stores, their prices were typically the same or sometimes cheaper than online.
Router: DeWalt DW618PKB Fixed/Plunge Base Kit, variable speed
- Bought from Home Depot for $199. Selling points to me were that the guides on the plunge base were larger in diameter than most of the other brands and had less play in them. The built in dust collection was also a selling point where for the others I looked at it wasn't offered, or was an additional accessory. They also have a 3yr warranty and free servicing in the first year.
Saw: Skil MAG77LT Worm Drive Saw
- Bought from Home Depot for $175. It was the cheapest worm drive saw I could find with a cast base. I wasn't particularly impressed with the quality of stamped bases I saw on some other saws. Anything that'll help to give me a cleaner, more accurate cut. Using a home made saw guide I've been able to get panels that fit together very well. However, I'd definitely recommend a table saw if you've got the money and space as I've found it takes me quite a bit of time to set up each cut.
Random Orbital Sander: DeWalt D26453K, variable speed
- Also bought from Home Depot. They had it advertised for $79. But they beat competitor's prices by 10% and the DeWalt outlet store had it for $74. So that coupled with a Home Depot credit card discount of 5% brought it down to $63. I was leaning towards a Bosch ROS20VSC as I read they were a little quieter, but I don't think the DeWalt is loud. What I didn't like about the Bosch was that its dust collector was a bit of a pain to open and close, where the DeWalt had a simpler twist off mechanism. The vacuum adapter on the DeWalt is also built in, where the Bosch is separate (but caters to 2 diameters).
Shop vac: Stanley Wet/Dry Vac, 10-Gals, 4-HP
- On special at True Value for $40. Works great as a shop vac, but I wasn't that impressed when I used it to extract dust with the plunge base router. From what I've read, the dust extraction on the DeWalt router works well so I'm guessing the flow on the vac is maybe a little sub par. I thought it'd suffice as it's more powerful than many other vacs out there in that price range. You get what you pay for I guess.
Veneer: www.veneersupplies.com
- Quite a few members purchase from here, and the prices/selection was great. The first order of walnut veneer was unfortunately damaged in transit but they were great about getting a replacement on its way to me.
Router bits: www.mlcswoodworking.com
- Once again, a tip from other members. The prices/selection was good and shipping is free. Much cheaper than the local hardware stores.
I'll post some pictures of the build as it progresses. Hopefully this will help any new diy'ers considering their first build.
