While I posted many questions on this project on the technical talk forum, I finally finished my OS MTM "Boombox" for lack of a better phrase. After reading this forum for days and being totally inspired by the "Cougar" boombox, I wanted to build something similar but that didn't require the mobility, volume, and was a bit more "living-room friendly." After much research on settled on the OS MTM's for the LR and Surrounds, and augmented the low end with a Dayton 8" DVC SD215A-88. It took alot of time and I appreciate all of the help and guidance on this forum. I have alot experience woodworking but this was my first speaker build and to be honest I floored by the sound quality.
Some details. Cabinet construction is oak plywood with some MDF for the internal pieces. The baffles of the MTM's are some ash scraps I had laying around and the baffle for the woofer and trim are maple. The baffle is actually a piece 1/4 figured maple I had found and glued to 3/4" MDF. The baffles of MTM's on the main unit are actually angled at 5 degrees which definitely complicated the design and its unclear whether it added anything. I did preserve the internal cabinet volume for the MTM's. The sub volume ends up being about 1.25 cubic feet.
The oak and ash were finished with a Old Masters Gel Stain (several coats) which added the color, blended the woods, yet still allowed a fair amount of the figure to show through. The maple pieces just had BLO. The whole thing was then covered with ~8 coats of a self-made wipe-on poly.
Final main unit is here:
Here is the back (opened up to show the internal construction). The back panel has a coaxial radio out, a rocker switch that controls power to everything while still providing low power to preserve the head unit settings, and the surround outs
I have also a bunch of build photos I can add if interested. Not a ton as I was not very good at remembering to take the pictures.
