The Aspen
  • The Aspen
    Hats off again to Paul Carmody, another build of an OS Boombox. Thanks also to Gordy and his Madeleine, who was the initial inspiration for this build. Although not nearly as elegant as the Madeleine, I'm very pleased with the end results More pics and an abbreviated build log later, but here's a preliminary look...Click image for larger version
ID:	1189557Click image for larger version
ID:	1189558Click image for larger version
ID:	1189559Click image for larger version
ID:	1189560Click image for larger version
ID:	1189561 Why "The Aspen"? Made from Aspen lumber, interesting wood to work with!
    Re: The Aspen
    Very cool.
      Re: The Aspen
      You do some really nice woodworking and finish look flawless.
      Wondering why you didn't put the tweeters above the woofers?
        Re: The Aspen
        Thanks, it's not apparent in the pics because I'm shooting down on an angle, but the tweeter c/l is slightly higher than the mid. I'll post some assembly pics later, but there is a horizontal divider in the box, separating the drivers from the amp and Bluetooth module. That being said, the tweeters probably could have been moved up a bit, but it doesn't sound like it's affecting anything. Only have a few hours on them, still breaking in.
          Re: The Aspen
ID:	1159375Click image for larger version
ID:	1159376Click image for larger version
ID:	1159377Click image for larger version
ID:	1159378Click image for larger version
          Basic box, front baffle.
            Re: The Aspen
ID:	1159380 Front Baffle
ID:	1159381Click image for larger version
ID:	1159382Click image for larger version
              Re: The Aspen
ID:	1159384Click image for larger version
ID:	1159385Click image for larger version
ID:	1159386Click image for larger version
ID:	1159387Click image for larger version
ID:	1159388 After Sanding, ready for conditioner and stain.
                Re: The Aspen
ID:	1159389Click image for larger version
ID:	1159390Click image for larger version
ID:	1159391Click image for larger version
ID:	1159392Two applications of Minwax "Gunstock" stain, 4 coats of Deft Laquer. After seeing what the stain looked like, I decided I wanted Brass corners instead of the black I initially bought. Hard time finding them, these are antiques from a 100 year old cabinet making company that had gone out of business. They warn you ahead of time they're not new, expect some blemishes and tarnish. Gave them a light polish when I got them to clean 'em up, lacquered them as well. Like the old patina on them....
                  Re: The Aspen
ID:	1159393Click image for larger version
ID:	1159394 Same shots as from the beginning. Basic OS construction, crossovers in the speaker enclosures, drilled one hole per side to the upper section of box to connect to amp (sealed after wires run through). Upper section has amp screwed down with 3 L brackets, Bluetooth module, and wiring for the outlet on the back for phone or computer charger. Rear facing 6" ports. No battery, have an outlet near our firepit where it will be used most of the time. Thanks again to Paul Carmody for the OS design, and others whose ideas have contributed!
                    Re: The Aspen
                    This is a great looking project! I am a big fan of using hardwood for speaker boxes (even thought it has its drawbacks)
                    The Madeleine
                    The Roxster
                    Swopes 5.0
                    Acoustic Panels
                    Living Room Make Over
                      Re: The Aspen
                      Thanks Gordy! Aspen turned out great for this project...it's a soft hardwood that machines easily and took the stain well. It's known for being very stable, and it's light weight (compared to oak for instance) makes moving the unit around easier.
