My first build - Overnight Sensations
  • My first build - Overnight Sensations
    Well technically it is my 3rd build but the first 2 were over 30 years ago when I was in my early 20's. I built them out of designs from a Philips speaker building book I had purchased. Then of course I used Philips components and crossovers which I was able to purchase locally. I built the cabinets myself out of particle board and then veneered one set and painted the other. The first set had a small cabinet just large enough for a 4" woofer and a dome tweeter that I used as speakers for my car. The second set was larger and had an 8" woofer, a tweeter and a port. This set I built for my sister.
    So this is my first "serious" build. I was looking for a set of speakers to use on my desk to listen to music from my computer and thought why not build a set. I searched the net and came across the "Overnight Sensations" by Paul Carmody. Then I read every thing I could find on them; people's impressions, peoples builds, and that was it. This was perfect for my needs. They were inexpensive, easy to build, everyone said they sounded great, and there were so many people who documented their builds with a variety of finishes and lots of tips. I used tips and finishing ideas from several other build posts especially from "Soundslike" and "rdrowley" and am very happy with the finish of my set. I veneered the sides and back and painted the front baffle. I purchased a Lepai LP-2020A+ amp to run the speakers.
    Most importantly I couldn't be happier with the sound quality, I am by no means an audiophile but they sound great. I plan to replace the Lepai LP-2020A+ with the Lepai LP-168HA 2.1 and build the Voxel mini sub to make them into a 2.1 system as mentioned in Paul Carmody's Voxel post. Thank you everyone who has posted info and documented their builds online and especially Paul Carmody for giving us his designs.
Name:	Overnight Sensations, Speakers _MG_0547.jpg
ID:	1189684Click image for larger version
Name:	Overnight Sensations, Speakers _MG_0543.jpg
ID:	1189685Click image for larger version
Name:	Overnight Sensations, Speakers _MG_0618.jpg
    Re: My first build - Overnight Sensations
    Those look great.
    Nice job!!!!
    Is that walnut veneer?
      Yes, those ARE pretty.
      I bet they sound good too.
        Nicely done
          Thank you for your kind words.
          The veneer is actually Cherry. I had originally considered staining the veneer a lighter shade of red to match the red baffles but when I tested the stain on a piece of veneer and held it up to the baffle, I didn't like it. I prefer the contrast of the natural colour of the veneer against the red of the baffle.
            They look real nice, and the photography work is pretty good too!
            TomZ
              TomZ
              Thank you !
              Our children moved out on their own several years ago and since then I have had the time to get back into some of my old hobbies. The first was photography and the now the second is speaker building.
              Gary
                Where can I find that veneer?
                  I Bought it locally at a store called Win***r plywood. (not sure if we are allowed to use company names). They have stores in western Canada as well as Washington and Montana.
                    That veneer will get darker and redder with time. -- Doug
                      It's interesting you should mention that. I had been thinking for the last little while that it looked darker. Those pictures were taken a couple of months ago.
                        I've not yet built my first set of speakers. I'm doing a lot of trolling and picking up a lot of useful info. A lot of you guys are making some really impressive looking speakers, but no one ever seems to compare the sound quality of the built speakers to anything which is manufactured. So, when one asserts that a particular build "sounds great" against what is someone else to compare?
                          I'm assuming instead of trolling you meant trawling :D
                          I can't speak directly for the others on this forum, but I do have a manufactured set of speakers right now that I will compare against. I also am building my set because I enjoy the challenge of it. To me, the journey I take in building my cabinets and crossovers is almost as important as the end result. It gives you a sense of pride.
                          Granted a lot of builds that use expensive components end up saving money in cabinet material and construction costs when compared to similar manufactured designs. The point is as I said though, to enjoy your project, both before and after it is done
                            I completely agree with the joy of the challenge, but I want a pretty high degree of confidence that a kit I assemble ( not even close to wanting to tackle crossovers yet) will provide truly impressive sound. I get the sense that most who are into speaker building do it because they have found that the product is as good as or better than what is available at the nearby big box, but no one is comparing their product against brand x or y. So how would I know whether the Overnight Sensations compare to a Polk or a Bose or a JBL,... etc.? And without such, how would one know whether to buy one kit versus another?
                              Where are you located? I'm sure there is someone close who can let you listen to a design locally.
                              That will help inform you,
