Jazzman's SLS Ripole Subs
  • Jazzman's SLS Ripole Subs
    SLS Ripole Subs
    Jazz
    Jazzman's DIY Electrostatic Loudspeaker Page
    Re: Jazzman's SLS Ripole Subs
    Nice job, man! It's amazing how much bass you can get out of a "no box" subwoofer, ehh! Clean and very musical, too.
    A mains
    The Ventures
    Open Invit8tions
    RSR
    Sound Troopers
    Acorns
    442
    DGBG's
    The Monuments
      Thank you sir. They blend quite well with my hybrid-ESL mains too.
      Jazz
        Do you mind me asking if the threaded rod is used solely to assemble the three pieces, or do it also serve another purpose?
        Sausage With Meat Sause, Please
          The threaded rods only serve to hold the box pieces together and to allow easy disassembly, should the woofers ever need replacing. The woofers can't be installed or removed with the box assembled.
          Jazz
            Thanks.
            I can only imagine how nice it must sound. Congrats.
            I am using the 12" SLS in an OB design, paired with a 3.5" Vifa.
              Are the placement requirements the same as a regular dipole sub?
                Very cool - thanks for sharing.
                Are there general guidelines for what woofers can be used in this configuration?
                I have some 8"s in a sealed cabinet that aren't working out so well. Gaining another 5 or 10 hz in extension and a tiny enclosure might make them a perfect setup for my wife.
                  I would say probably yes, as the radiation patterns are similar; although not exactly: Whereas a dipole's front/back radiation pattern forms a figure-8, a Ripole's pattern is somewhat cardroidal (heart shaped).
                  Jazz
                    There is a tradeoff, as you would gain extension but lose some efficiency. I myself am not an expert on Ripoles so I will refer you to any and all Ripole related posts on the DIY Audio Forum by a guy that goes by the user name "Rudolf" (he may even be a member here). Specifially; THIS POSTING
                    Jazz
                      Looks like great info in that thread. Thanks for the link
