So I have been working on these speakers for a while now, but have just got around to playing around with the filters and taking some measurements. When I started this build the whole idea was that I wanted to try gluing veneer on a round over and using 2 different types of veneer. Then I picked the W4-1052SDF driver because it seemed that it wasn't used very much(searched the forums) in builds. Then about half way through building the cabinets I stumbled upon Rory's old website (correct me if it isn't his) and found the Whetstones. Oh well, so much for being original:D I decided that because his project was about 4 years old that I would take my own measurements and design my own networks so I can learn some more along the way. The speakers were very bright and a bit weak in the bass department running without any filters. The baffle step and notch filter seem to take care of that. It was neat to swap out filter parts with different values and see the small changes it made in the response curves.
Projected response in PCD
And measured in room response. Mic placed 20" away from speakers.
A few build pictures,
Applying the first strip of veneer.
Filling in the gaps with a small strip of veneer and some super glue.
Drivers going in.
I put on about 5 coats of Tung oil and then 3 coats of poly. Boy does that Tung oil stink!!
I might spend a bit more time messing around with the filters before soldering them together and putting them in the cabinets, or just leave it the way it is as I am happy with the sound. I would also like to build a matching sub to go with these for a nice little 2.1 setup for the bedroom or office.
Drivers going in.
