I made a home made talk box from my peavy vypr15 guitar amp. What I did was wire a switch to direct the current from the amp to either the horn driver (for the talkbox) or the woofer for standard guitar playing. I used various PVC connectors to run the sound from the horn into vinyl tube that acts as a portal for the sound. Pictures coming soon (having an uploading problem)
Home made talk box
Re: Home made talk box
I used the EMINENCE ASD1001 1" HF TITANIUM HORN DRIVER 1-3/8"-18 TPI (part number 290-525) and a DPDT HEAVY DUTY PADDLE SWITCH CENTER OFF (part number 060-598) for the switch... I'm still having problems uploading the pictures but for now I'll post a youtube video that inspired me to build it. https://www.youtube.com/watch?v=qqIqxM-BNp0
Finally figured it out. The maximum file size was too small and most of the pictures were 3-4mb each. I shrunk them down.
here I have the horn driver theaded into a piece of pvc and the pvc glued with epoxy into some scrap wood I had laying around with a hole drilled into it I also have an adapter inside there (cant remember the sizes)
From there I needed something smaller to fit the vinyl tube into so I used a what I could find
here I inserted the tube and it wast quite tight so I used a generous amount of silicone sealant to make sure no sound escapes.
smaller tube fits inside the larger tube
wiring the switch
I used epoxy to glue the switch on that wood I used to mount the horn driver and also screwed that into the amp box
Here's the wiring diagram I made with microsoft paint :D
finished product
Let me know what you guys think. Personally I like the sound I get from it and am extremely happy with how it turned out... I haven't been able to stop playing it.
I hope your already thinking about making a stomp box switch for it ;) nice project.
Wow, that takes me back a ways... Used to be a guy at college, would play out on the quad, built one with a 5-6" woofer in a tiny sealed enclosure, battery powered amp, fully portable, etc. Quite the feat back in the late 70s. Said it was an experience to play, with resonances in your chest on certain notes, etc. Sounds like fun!
Originally posted by 6thplanet View PostI hope your already thinking about making a stomp box switch for it ;) nice project.
Originally posted by dougman View PostThe thought has crossed my mind but given I do not have a mic or pa to use; the foot switch is rather useless to me because the woofer is roughly 3.5 trillion times louder than the horn driver for the talk box. whenever I switch the output I always need to turn the volume way down and adjust from there.
Originally posted by MattB101 View PostYou need a couple or resistors or a "L" pad in the feed to the squad box to adjust once and forget, then a stomp box makes sense.
