Infinity 1262W build with reclaimed wood
  • Infinity 1262W build with reclaimed wood
    Many thanks to those who chimed in on my other thread, it was a big help. Specifically fwhiler who posted a pic of his enclosure which in turn inspired mine. I used Bagby's spreadsheets to dial in my enclosure:
    I had an oak cabinet I previously built for my media alcove which I carefully pulled apart to use for my enclosures (I'll have 2 eventually). Figuring out how to get the most out of what I had, took some time and really steered the design. The original oak cabinet:
    This was a fun quick build once I figured out how everything was going to fit. I used glue, biscuits and nails to secure everything. The enclosure was built first and the trim pieces were added last. Outside dimensions are about 18 3/8" all around which once the 11/16" panels are subtracted equates to 3.24 ft^3. After internals are subtracted it's closer to 2.75 ft^3.
    This was my first time dealing with a port this size, and it was a chore to make it work. I used 4" irrigation pipe to make it (the cheapest I could find) and added a brace to the main riser. It's very stable.
    The bottom trim pieces hang down about 1/2" to help conceal everything. The bottom baffle is a total of 7/8". Sub is surface mounted and the port opening has a 3/8" roundover. My glaring oversight on this project was the Neutrik connector. What I purchased is for a thin panel and definitely not for an enclosure. I was able to make it work by recessing it, bending the tabs and using an oversized gasket.
    Here it is in it's current state. I'm waiting to complete the 2nd enclosure before the final finish.
    I've been using it for about a week now and I'm very happy with it. Currently it's crossed to my mains at 80 and is powered by a Inuke 3000DSP. It's more then enough to shake my house, so much so, my wife wonders if we even need a second one... I can't wait to get the second one done.
    Re: Infinity 1262W build with reclaimed wood
    I love it man!
      Very nice!! Love the rustic looking finish. Care to share the details?
      John
      God created man,
      Sam Colt made 'em equal
        Smart work. Nice job!
          Wow that looks great! Nicely done
            Thanks guys! This was a very rewarding build for me because it was my own design. I learned quite a bit along the way, and a lot while running numbers to determine my enclosure. It was fun and frustrating at the same time.
            John
            Finish is pretty straight forward at this point. About 7 years when I built the cabinet, I brushed on a couple coats of Cabot Ebony. After disassembling the cabinet for the sub build, I sanded everything using an orbital sander and 120 grit discs. I used that to take of the bulk of material. Afterward I used a hand sander with 220 (I believe), sanding with the grain, to eliminate the swirl marks from the orbital. That's where I'm at currently. I was planning on rubbing it down with Dark Walnut Danish oil, but it may be too light for the rest of our furniture. I have some decent size scraps so I'll be able to test it as well as a couple other finishes.
            The hard part will be the trim pieces. I had to cut them to width which exposed bare oak. I'm not quite sure how to approach that just yet.
              My kind of guy.. if one is fabulous, two is much, much better!!!! All the best, Mike
                That is really very nice looking. Good work and thanks for sharing.
                  Very nice looking!
                  I'd certainly put 2 of those in my living room. How much you asking for the pair?!?!?
                    I love it, a speaker that looks great too. Personally, I like the two tone of the trim pieces. YMMV.
                      Very nice looking! Now I know I'm not the only guy in SWRC feeling the Infinity love!
                        Rotech - I actually may end up giving the enclosures to a friend in the next year lol. I plan to upgrade my mains later this year, and the current plan is to build two tall mains with subs incorporated.
                        lhurt - I do too and was originally going for something close to that, but the wife would like them darker to match the rest of our furniture. At the rate I'm going though they may not get finished
                        manu - I'm definitely enjoying this sub. I do want to add some stuffing and possibly more bracing, to see if improvements can be made. Thanks again for your input on the other thread, it was very helpful.
                          I used my kids as weights and am looking for a granite remnant now to add to the top as the added mass cleaned it up at high volumes for me, which we only get to do when mom is not home.
