I need a set of speakers to attach to my PC. I could go to Best Buy and get a pair for $15, but no, I'm compelled to make my own. The cabinet size I was looking to create is just within the capabilities of the printer. The shape is a truncated cube 110 mm across.
At this point, I've got a shape that will print in one pass. This is actually a challenge because while you can do sloping sides, you can't print a ceiling without support. To get around this I have a conical shape coming from the sides to just under the driver opening. This not only holds up the top (front actually), but is also gives a thicker material for screws to hold the driver.
Flush mount is sized for the Dayton RS-100-8. The enclosure, sealed in this design is 1.1L (0.039 ft^3) and should be about right for the RS-100. The walls probably aren't thick enough yet (2.5 mm except on baffle where it is up to about 10 mm).
Maybe the ND91 would be a good choice for this project. Similar size and price range. Flush mounting is a little harder, but certainly within the capabilities of Sketchup.
