Trans-lam Caritas finished
Re: Trans-lam Caritas finished
Nice looking cabinet... and I love the angular treatment on the top! I haven't seen that done before I don't think.
TomZZarbo Audio Projects Youtube Channel: https://www.youtube.com/channel/UCEZ...aFQSTl6NdOwgxQ * 320-641 Amp Review Youtube: https://youtu.be/ugjfcI5p6m0 *Veneering curves, seams, using heat-lock iron on method *Trimming veneer & tips *Curved Sides glue-up video
Oh man. I want that cabinet in my living room right now!Isn't it about time we started answering rhetorical questions?
Twitter: @undefinition1
Fantastic looking! I especially like the book-matched tops.
Very attractive speaker." To me, the soundstage presentation is more about phase and distortion and less about size. However, when you talk about bass extension, there's no replacement for displacement". Tyger23. 4.2015
Those speakers look great! Well done!
I hope I can ask some basic translam questions here, I wish to try this type of assembly in the future. When you are gluing up the layers, did you run dowels through the pieces to aid alignment, or just line them up as best you can then sand the crap out of it afterwords? Also, I assume a clear adhesive like contact cement is preferred for gluing up the layers, as opposed to regular wood glue?
Thanks.I'm not deaf, I'm just not listening!
Thanks.
This is the bottom during the clamp up. Hard to see but there is a rebate (rabbit? It's Easter!) that will hold the mdf bottom. The bottom panel also houses the crossover and the port. The location of these allow the down firing port.
Sand sand sand….This little porter cable does a good job, and hooked up to the big ridged vac and dust deputy, is pretty darn clean.
Just a shot of the back.
And one of the top.
Jay
Oh the glue. I used Titebond melamine glue. I had most of a bottle left over from another project and it seemed like it fit my application. The plywood I used has a smooth phenolic face, wood glue won't penetrate and become part of the wood like it wants to. If you are using normal wood faced ply, use your favorite wood glue, maybe the extended open time titebond would be best. Wood glue is unbelievably strong.
All that said, I tested the melamine glue and titebond ii on some scrap pieces. I glued a couple scraps together in a "x" shape, leaving little handles to try and pull on. I could not budge either of them.
Jay
Thanks for the tips, you've been a great help. My plan is to have laminated side panels that fit onto a normal flat front and rear baffle. This way I maximize material usage. My boards will be CNC cut, and I had planned to have a couple holes in the panels for dowels to help the boards line up and prevent them from slipping out of place as they dry.
My comment on the glue was more about the fact that normal wood glue tends to soak in a bit and dries yellow or brown. I guess its such a thin layer that is not noticeable after you send the edge back.
Thanks again.I'm not deaf, I'm just not listening!
Very nice cabinets! You make a budget speaker look like a million bucks!
