Living Room Build Out
Last edited by Gordy; 07-03-2015, 09:38 PM."A dirty shop is an unsafe shop, if you injure yourself in a clean shop you are just stupid" - Coach Kupchinsky
The Madeleine
The Roxster
Swopes 5.0
Acoustic Panels
Living Room Make OverTags: None
Re: Living Room Build Out
You're so dang talented. I need to redo my living room, but I'm going to end up hiring someone to build an audio rack. Nice work!Some people are addicted to Vicodin. I'm addicted to speaker building.
LM4780 Parallel Chipamp
Sonata Soundbar Project
Nice job! While your at it you might think on incorporating A way to organize the wires on the back. I built a little slide out tray between the wheels underneath the last one I built and it worked great.‘There are none so blind as those who will not see.’
The Madeleine
The Roxster
Swopes 5.0
Acoustic Panels
Originally posted by bret191 View PostNice job! While your at it you might think on incorporating A way to organize the wires on the back. I built a little slide out tray between the wheels underneath the last one I built and it worked great.
The wires in the back are not really an issue as they just hang down. The back is accessible but tying up and organizing wires would be difficult. I can fit enough of my body thought the side storage area to get to what I need to. I had to be able to plug in the power-strip in and get to the coax and Cat6 plug.
The Madeleine
The Roxster
Swopes 5.0
Acoustic Panels
The Madeleine
The Roxster
Swopes 5.0
Acoustic Panels
Nice work. It really comes together with a great look. You knocked those crossovers out of the park though, shame you hid them in the cabinets!Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
Sites: Jupiter Audioworks - Flicker Stream - Proud Member of Midwest Audio Club
what biscuit jointer do you have? My neighbor has a porter cable handheld one we used a few times it did help line things up a lot easier. Especially for doing solo glue-ups. We mainly use it for table tops though.My Build Thread's
Carrera's / Finalist TL's / Speedster TMM's / Speedster MTM Center / Overnight Sensation Surrounds
Originally posted by JasonP View PostNice work. It really comes together with a great look. You knocked those crossovers out of the park though, shame you hid them in the cabinets!
Originally posted by Mike220 View Postwhat biscuit jointer do you have? My neighbor has a porter cable handheld one we used a few times it did help line things up a lot easier. Especially for doing solo glue-ups. We mainly use it for table tops though.
Originally posted by ksneote View PostI may be off base here, but wouldn't there be issues with having a rear facing port and having them mounted as you have? Is there enough room around the speakers and shelfs for the rear waves to propagate out?"A dirty shop is an unsafe shop, if you injure yourself in a clean shop you are just stupid" - Coach Kupchinsky
The Madeleine
The Roxster
Swopes 5.0
Acoustic Panels
Excellent project. I looooooooove built ins. Seriously, ask my wife. I won't shut up about them.Isn't it about time we started answering rhetorical questions?
Twitter: @undefinition1
Originally posted by Paul Carmody View PostExcellent project. I looooooooove built ins. Seriously, ask my wife. I won't shut up about them.
I recently was commissioned to make a simple mantle shelf for a friend of mine for his foyer. I thought it would be a good opportunity to try the spraying of oil base again. I researched heavily and all I found was "just thin the oil base with paint thinner and shoot it out of the $20 purple Harbor Freight HVLP" Since I wanted to specifically shoot with an HVLP I thought, how could I go wrong?
So I picked up a purple Harbor Freight HVLP sprayer, a good regulator (I converted one of my wall outlets to a regulated outlet and had it in a box brand new for years), $20 light weight poly hose and I was spraying like nobodies business. At an 80 degree temp, I ran it with 2:11 thinner to paint and 50lbs to the gun. I have since used this combo several times all with good results and have a lot more to spray. The unit being built and the open spaces above it will get face frames and cabinet doors.
The downer, I can get the oil base to lay mirror smooth If my prep work is not good enough you can see the imperfections. Not like putting it on with a brush. I will be ordering cabinet doors in the next few weeks. the paint process is lengthy. You spray, let it sit untouched for 24 hours...let dry an additional 5-6. After this the parts can be worked with without printing."A dirty shop is an unsafe shop, if you injure yourself in a clean shop you are just stupid" - Coach Kupchinsky
The Madeleine
The Roxster
Swopes 5.0
Acoustic Panels
Thanks for posting the details. I'm always curious how others approach built ins. Can you elaborate a little more on your paint process? i.e., did you spray the carcass and face separately and then attach? Looks like minimally a first coat was applied to the carcass without the face.
