Re: Living Room Build Out
I was actually painting a mantle shelf for a friend of mine and it was going so well I decided to spray the inside of the unit to see if I could get the gun inside and get in and around the corners. It was already primed. Yes, I did then build/attach the front face frame and then primed and painted it and reshot the entire unit including the inside. This was also the time I sprayed the top. I had it down. I could not get a run to save my life.
The paint process itself was pretty simple. All surfaces were primed with Kilz Low Odor rattle can. It is an oil base and it drys fairly quickly and it is rough. You can actually build with it and after it drys, hit it with 220 grit and it is butter smooth. I used Behr Premium Oil base. 4oz of paint thinner and 18oz of paint. Stirred and mixed in a cup and poured through a filter into the cup of the gun. I used 50lbs of air and adjusted out the gun.
I have another frame to paint in the morning. This one goes above the TV in the empty spot. One this is done and mounted in, i will order the cabinet doors. I think once the cabinet doors are done and installed it will really take shape and start to look like built ins.
Originally posted by fixthedoor
View Post
