Many months passed , and test been done on my XO and the final is here:
ACCUTON C30-6-024
ACCUTON C173-6-090
2x Seas L26RFX/P
I have some questions , if you have time I will appreciate if you have any time to answer those. Or maybe suggestions. New XO design for my speakers. Everybody suggest to change my XO from First order one to Second order XO) Because of the usage of 3 -way concept and the overlapping frequency on the first order XO. Everything is a closed box design.
I`m back from second order XO for the tweeter to first order XO. That sounds best for me.
I`m testing now for my C30-6-24 Accuton on Duelund CAST 8.2uF + 1uF and 0.01uF ( I have some spare Duelunds so I will test it more and add some more ) any advice ? )
I have also done some bypass 100kOhm on my caps and resistors, but this was nothing special. ( Sugestion fro Tony from Humble ) Maybe I will test it again later on. Have you any experiences on this ? Bypassing all with 100kOhm resistors on Caps and Resistors? Tony form humble site dit so to add some “peace, rest” to the sound.
I`m now buying 50uF Cast for my Middleton speaker ( so all will be Duelund: 54uF Cast + 40uF VSF). Tony from Humble have sayed to me to inverd the phase on my middleton speaker for beter frequence response. ( of couse if i wil go for seccond order XO for the tweeter ) ( but My Tweeter on seccond order XO was some kind restricted vs first order XO.)
Connect plus pole to min Pole. But for my taste the Bass slam is lost if I do this on my Speakers. So I left the Middleton speaker connected not in inverted phase. And Bass is now deep as i like it. Did you ever test it? ( see diagram )
I have also upgraded my internal cables with some Western Electric WE16GA.
My XO looks now like this :
In the red Box on the XO i have tested and this things dident sound good to me. ( Only did not tested on the Bass what is in the red box )
I`m missing some smoothness on my Tweeters and high-mids. The capacitors isen`t a issue ( i have Spare Mundorfs Supreme S/O , Audyn True Copper , Rike and so on ans on)
Now i`m using on the 3Ohm Path-Audio resistor ( have also tested Duelund CAST )
The 100K Ohm parallel on the tweeter cap was only for testing , now its not there anymore .
ACCUTON C30-6-024
ACCUTON C173-6-090
2x Seas L26RFX/P
