So, I'm going to put together a boom box and I'm wondering if I need to have an in-line fuse. I'm using a Sure 15x2 amp with the Sure bluetooth module and 2 Dayton ND90's. I'll be using a 12v power supply brick. Do I need to add a fuse?
Boom box fuse?
It could not hurt. The fuse needs to match the amperage of the AC adapter. I put one on every boom box I make."A dirty shop is an unsafe shop, if you injure yourself in a clean shop you are just stupid" - Coach Kupchinsky
The Madeleine
The Roxster
Swopes 5.0
Acoustic Panels
Living Room Make Over
Short out your battery for a few min and see what happens ;) Then go back in time and provide a fuse as close to the battery terminal as possible."I just use off the shelf textbook filters designed for a resistor of 8 ohms with
Originally posted by Jeff F. View Post.... Do I need to add a fuse?
http://www.optifuse.com/PDFs/FuseSel...Guide_RevA.pdf"Not a Speaker Designer - Not even on the Internet"
- 1 like
Thanks guys, I think I'm going to go with this fuse holder http://www.parts-express.com/littelf...m_campaign=pla maybe a 3 or 5 amp fuse
This one is my personal favorite. It uses a GMA 5x20mm fuse so it keeps it small and has little depth. It also allows accessibility from the outside if you are using a dish as well.
http://www.parts-express.com/screw-c...black--070-612"A dirty shop is an unsafe shop, if you injure yourself in a clean shop you are just stupid" - Coach Kupchinsky
The Madeleine
The Roxster
Swopes 5.0
Acoustic Panels
Originally posted by Gordy View PostThis one is my personal favorite. It uses a GMA 5x20mm fuse so it keeps it small and has little depth. It also allows accessibility from the outside if you are using a dish as well.
