Good morning guys. I know I have seen this topic before but checking to see if any other fresh ideas have surfaced. I have a PVC port tube I want to glue in to my MDF baffle. I will have a double thickness of material at that point. I am thinking I will use a 2-part epoxy for the joining. Comments or suggestions?
Best gluing technique for adding PVC ports
One vote for hot melt glue. Kinda the neat thing is, if you use a plastic port with a flange mounted from the front w/o screws, you can lay a light bulb (60w) on the opening for a while and it will warm the glue enough that you can wiggle it back out.
I've been using caulk to install my PVC ports for over 20 years. I use the 100% silicon type, like the kind you'd use on a bathtub. I always double up the thickness of wood around the port to give it a nice mechanical hold, then goop it up with caulk, install the PVC, and wipe away the excess. I've never had any problems.
Originally posted by Psycoacoustics View PostFrankly, I've only built three pairs at this point in time and I just use whatever Titebond I'm using at the time. As far as I know,,,, they're still all stuck.
YMMV, Mark
I tend to use 2 part epocyll
I tend to use 2 part epoxy.... it is important to degrease it with alcohol or some solvent like was mentioned. But for a truly solid joint, scuffing the shine off of the surface with sandpaper will give the glue some roughness to hold on to.
