I need a circuit that will trip a relay momentarily, say 200-400ms, once after mains voltage (110V) is applied. I mean I switch the device on, and it will trip this relay once and that is all. I feel this is an elementary design question, but I'm no EE. Ideas?
Any EE can help with simple circuit plan?
Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
Sites: Jupiter Audioworks - Flicker Stream - Proud Member of Midwest Audio ClubTags: None
There are adjustable time delay relays sold.
( Most time delay circuits I've used have a longer delay time - usually seconds not milliseconds ).
http://www.bowdenshobbycircuits.info/page2.htm
Delay time in theses circuits is set by a combination of Capacitor and resistor values to set a common emitter."Not a Speaker Designer - Not even on the Internet"
Originally posted by JasonPI need a circuit that will trip a relay momentarily, say 200-400ms, once after mains voltage (110V) is applied. I mean I switch the device on, and it will trip this relay once and that is all. I feel this is an elementary design question, but I'm no EE. Ideas?craigk
When I turn on the power to several boards, I also need to trip the power switch on a motherboard.Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
Used a pair of DPDT relays in series for something like this once. First relay feeds the the coil of the second and "signal" goes through the NO of the first and NC contacts of the second. The second coil takes time to react but not sure how much. Enough in my case.
Sounds like for $6 a ICM102 Delay-on-Make Timer with .03-10 minute adjustable delay, universal 18-240 VAC might* do it.
* Load current?"Not a Speaker Designer - Not even on the Internet"
Originally posted by JasonP View PostWhen I turn on the power to several boards, I also need to trip the power switch on a motherboard.Electronics engineer, woofer enthusiast, and musician.
Wogg Music
Perhaps using Wake-On-LAN setting in BIOS?.
Originally posted by wogg View PostAre you talking about a computer motherboard? Those use a momentary contact on the front panel header to send turn on signal to the power supply. That's an important distinction since most delay relays are intended to turn on and stay on.
Yes, which is why I need a momentary click from the relay setup.Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
Originally posted by Sydney View PostPerhaps using Wake-On-LAN setting in BIOS?.Audio: Media PC -> Sabre ESS 9023 DAC -> Behringer EP2500 -> (insert speakers of the moment)
A good old 555 timer one shot perhaps. You could drive a small SPST relay to hit the MB header. Sent from my SM-G920P using TapatalkElectronics engineer, woofer enthusiast, and musician.
Wogg Music
I considered the "restore to on" setting in BIOS to tell the board to start when power is connected but I worry what would happen if the bios was reset somehow and I wasn't the one using it to reconfigure the board.
Perhaps others have had a different experience.
Originally posted by MillstonemikeThe BIOS has to be specifically programmed to change its parameters. The parameters are stored in non-volatile ram. I've never had an instance of the BIOS being "reset" without human intervention in the 30 years since PCs came out. Perhaps others have had a different experience.craigk
