I think I'll do the same run tomorrow on the .75" deep, non-tangent mouth guide.
3D printed waveguides
- 1 like
As people have discovered before, what is going on right at the throat is the most critical factor. I've got some other phase shield designs to play with, but I'm also going to have the wg that overhands the surround made soon, I think that will be another critical test. I also wonder how the throat angle effects things, but it might take going to the larger wg's to provide room to play. As it is the tangent mouth wg's around low/mid 50 degrees, while the non-tangent wg's are around 40 degrees.
- 1 like
Originally posted by augerpro View PostInspired by Sean Olive's paper I now do Direct Sound (0+10) and Early Reflection (30+40+50+60). As you said, it has really brought a better perspective to the response, especially the ER portion.
"Everything is nothing without a high sound quality." (Sure Electronics)
- 1 like
Originally posted by ernperkins View Post
Brandon, do you have a link or a copy of the Sean Olive paper?
Here you go: https://www.dropbox.com/s/0t38u949om...mance.pdf?dl=0
- 1 like
Whoah huge thread. I havent read. I was really pushing this idea a number of years ago and eventually just went seos. A lot of people here were skeptical. I hope you come up with something cool. Ive been toying with my cnc machine and 1.75" thick mdf. I dont have 3d CAM software though so its tricky. And 3d software is expensive for cncs.
Originally posted by ryanbouma View PostWhoah huge thread. I havent read. I was really pushing this idea a number of years ago and eventually just went seos. A lot of people here were skeptical. I hope you come up with something cool. Ive been toying with my cnc machine and 1.75" thick mdf. I dont have 3d CAM software though so its tricky. And 3d software is expensive for cncs.
I think Fusion 360 will generate tool paths for your CNC, and it's free to hobbyists.
Thanks, working my way through it and trying to find Toole's papers for the definition of the different types of tests (e.g. LW, PIR, etc.)
Originally posted by augerpro View Post"Everything is nothing without a high sound quality." (Sure Electronics)
Originally posted by augerproI think Fusion 360 will generate tool paths for your CNC, and it's free to hobbyists.
Originally posted by ryanbouma View PostYes I think you're right but its a huge learning curve and setup change. I probably should look into it though.
I've found F360 to be really easy to learn, compared to Sketchup which I hated. FWIW.
- 1 like
Originally posted by augerpro View PostAs people have discovered before, what is going on right at the throat is the most critical factor. I've got some other phase shield designs to play with, but I'm also going to have the wg that overhands the surround made soon, I think that will be another critical test. I also wonder how the throat angle effects things, but it might take going to the larger wg's to provide room to play. As it is the tangent mouth wg's around low/mid 50 degrees, while the non-tangent wg's are around 40 degrees.Dan N.
I'm playing with an elliptical flare right now, aiming for around 60-ish degrees at the throat. I actually used Dave's waveguide on the NE19 which worked pretty well. This time around I'm aiming for the least amount of depth possible that still provides the performance I want, and good AC matching.
- 1 like
