Update! I'll post results over the next few days as I progress. This post will be all SB Acoustics: SB26ADC, SB21SDC, and SB29SDAC. I also will have results for the CSS LD22, Dayton RST28 A & F, and SB19ST over the next few days.
Couple reminders, all of these have elliptical mouths. Measurement conditions are MLS with 7ms of reflection free signal, NO smoothing. The spikes you see around 24khz are artifacts of the sound card cutoff causing some crazy FFT math. This isn't my old monster baffle, so baffle effects start to show around 3khz and below. The most obvious sign is the waviness of response and ripples and dips that flip around according to angle. Anechoic response would be smoother and SPL would drop as you move off axis.
First up, version G for the SB26:
I would say we're done here, but for the heck of it I designed one with an oval throat, vertically aligned. I don't have measurements yet of that.
Unless you can design a phase plug similar to a compression driver, the key to a smooth top octave is to make the throat small, the closer you can get to an inch or so the better. That is why I was excited to see SB's new 21mm tweeter with fabric dome (no phase shield needed) and copper shorting ring! Results were very satisfying:
I have one last waveguide to test with SB19ST but with the above results and the fact that the SB21 has a shorting ring, makes me think spending more time on the SB19ST is unneeded.
Next is the big fabric dome SB29SADC. I reused the 8" waveguide from the TW29 tests I did. The SB29 looks a lot better, but still that big throat causes some issue. Still the directivity would probably match an 8" woofer well 1-1.5khz and you would have a smooth upper midrange and lower treble.
