i case some of you thought i'm being a wimp about the heat , thermostat in my shop a couple hours ago , it now reading 101 !
Rs180P/RS28F vs. small DC160 3 way
here's a look using factory curves and the BC25 measured on a different baffle . the 2 way is from measured response using the floor boundary . i'm thinking of adding an external port and taking some measurements out in the middle of the room today , when i do it looks like the BC25 is physically a drop in and i'll be able to get on baffle measurements of that ... getting closer .
2 Photos
Originally posted by jhollander View PostThe x-o is almost as much $ as the drivers...
more !!! $90 in drivers and $130 in XO parts ... lol
i was warned about this , but outta pocket it wont be to bad . i have the BC25's not doing anything , i also have half the inductors already and all the caps but the 20 and 70 uF . and that had me switch a couple of values here is what i got now ...
1 Photo
Originally posted by jhollander View PostCheck watts dissipated graph, in XSim, those resistors before the x-o are going to consume some power
where do i find said graph ? i looked , couldn't see it ...
John- I don't agree with the wattage sentiment, as proven by the result fs saw. You still have an AC signal, no matter what side the series resistor is on. This means the signal is still being highpassed in both mid and tweeter circuits. In the event the series and shunt resistors are both in front (rarely, and is a no-no) then they see the full bandwidth. In the event the shunt resistor is of small value, solo, and it's across the load and shunting a lot of power, then that could also be of concern.
I was referring to what 'filmslayer' (I shortened it to fs) found. In this case, the watts dissipated will not change if it's in series with a capacitor whether before or after it. It won't change as this is an AC circuit.
Originally posted by Wolf View Post'filmslayer' (I shortened it to fs)
and what i saw John was only 1.5 watt dissipation both circuits combined .
Edit *** just changed them around , and with the resistor after it was just slightly higher than 1 watt in the tweeter circuit ...
