Originally posted by crossbound
View Post
Am I on the right track? Bookshelf speaker Fountek FW146 / Dayton DC28F
After removing the large resistors in the highpass to start over, I tried again, but added resistors in series with the capacitors, which seemed to help to keep everything a little more even and more manageable. Currently the reversed null is not dipping all the way down. I could correct that by increasing the C9 and C10 capacitor 5.1uF, but it would elevate the SPL in the crossover regions just slightly.3 Photos
There's a thousand ways you could design this x-over, so don't take my suggestions as an indication that you are doing something wrong. . Just as an experiment, try adding 1, 2 or 3 ohms for R12, and tweak the caps a little.
If you put 6 ohms in parallel with the tweeter, it will tend to level the tweeter impedance. That sometimes makes it easier to get the desired roll off. It will probably change the top end too.
Originally posted by crossbound View PostMy question is then, which impedance range should I shoot for?
Keep in mind that a tube amp won't like the wild swings in impedance. A Class AB will be fine with it. A Class D might have altered response in the top-octave depending on tweeter impedance in this range due to the typically standard output filter they use to suppress the switching frequency at output.
Once again thank you guys.
I'm not planning on using a tube amp so no problem there.
I guess my question now would be: is what I got acceptable, or are there any glaring issues I should take care of?
I will try some more tweaks, but sure would like to wrap this up. :-)
Wolf is there a certain impedance that you try to stay within to minimize the effects or are you designing for a certain type of amp in mind? I know next to nothing about amps.
It was just a statement and info to be aware of. Being that most Class D filters (some have another method that negates the effects by not having an output filter) are generally 1st order and 0.01-0.022mH in use. You can use the classic mH equation; L = [R/(2*pi*F) ]* 1000
In general, lower impedance means lower Fc of the coil, and an earlier rolloff ensues. Most are meant for 4 - 8 ohms.
You are doing fine. At this point anything else you decide to try will be for sheer learning and practicing. I can't tell you the number of Sims I have done just for experiments and learning. Wolf is definitely more versed at the terminology, some of the things that I mean aren't necessarily how I convey them... lol. If you chose to continue more experiments trying to flatten the impedance phase swings, then by all means do so. You aren't bothering any of us I'm sure. I personally like seeing these types of threads as they are great learning resources for more people than just yourself. I did the same thing when I first started. I also messaged Wolf and rpb plenty of times about theoretical builds and Sims to get their insight. For me it has been a pleasure trying to give you help and advice. Wouldn't you know it, I picked up a couple of tricks myself.
HAGD,
Marc
Even though I try to tell everyone upfront, understand that I am still a Newb. I wish the status of Seasoned Veteran/Senior Member, etc. was earned with time not posts...
TMWW thread
Maurbacs DCR Tower
What I learned tonight: As I was trying to reduce the impedance a little bit, I discovered that L1, C2, C9 and C11 had the biggest impact on reducing the impedance bump at 1500Hz. I reduced L1 just slightly, and increased C9 and C10. Also realized that R7 controlled the impedance bumps at 20Hz and 70Hz. And finally some other slight adjustments to keep the phase in line.3 PhotosLast edited by crossbound; 09-05-2016, 09:22 AM.
