Had been thinking about buying myself a turntable and that turned into me building one from scratch. Of course I've already spent more on this project than I ever would have buying one, but that's just part of the fun.
I found a piece of live edge curly maple to use as the plinth:
And I am using end grain maple and walnut for the platter. It's 1.125" thick and the grain is fairly consistent so hopefully it stays fairly flat. Where the tape measure is sitting will be about the edge of the plinth, approximately 18" x 20"
The bearing assembly I'm making will be tall enough to hang below the 2" plinth, so I made this base to hide the feet, the bottom of the bearing assembly, and house the motor controller. The base is a piece of baltic birch edged with walnut.
I looked around me and constructed a rudimentary lathe.
And on the underside of the platter I have routed a fairly substantial groove to fill with lead shot to add some inertia. The wood platter weighs about 2.3 pounds and this is about 5.3 pounds of lead.
The drive system is going to be a brushless camera gimbal motor. Initially this will be open loop speed control, but if that isn't consistent enough I'll be adding some hall effect sensors.
I will be building a passive linear tracking tonearm but all I have to show on the tonearm so far is this 8x10mm carbon tube that fits my headshell.
This is going to be a fairly lengthy project, but hopefully fun. And maybe by the time I'm done I'll actually own some vinyl!
