I turned this on my lathe, and took some quick and dirty measurements. The measurements were just to check the waveguide behavior, not for modeling. I believe this is useable. I should tell you guys that I first made a makeshift tracing attachment so that the wg can be duplicated. Obviously I still need to back cut it, and drill it for mounting, but I haven't decided if I want to flush mount it or leave it proud of the baffle and construct the grill tight around it like a vandersteen.
Aluminum Waveguide
Holy Cow! Is that 6" round bar? That must weigh a lot. I'm not a waveguide person yet, but that is just stinking impressive.
You really need to incorporate that chunk of aluminum into the box somehow in a way that allows it to be seen.
Well, now that I think about it... since you're using a big 'ol chunk of aluminum instead of MDF, I suspect you must be planning on featuring it in some fashion. Duh.
Reminds me of a chunk of 3" round bar 1 1/2" thick I purchased a few years back that I am planning on machining, and using for a volume knob for a future amp build. It is pretty heavy, can't imagine how much that weighs.
Nice!
TomZ
Nice! What tweeter did you use? I would definitely consider flush mounting."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
http://www.diy-ny.com/
Nice job Nick, that's sweet. You're really gonna listen with the grill on so you can't see the aluminum waveguide you milled? No way. Flush mount it and let it be seen!
Dan_____________________________
Tall Boys
NRNP Computer Sub
The Boxers
The Hurricanes
The Baronettes
Conneccentric
UX3
Originally posted by DanP View PostNice job Nick, that's sweet. You're really gonna listen with the grill on so you can't see the aluminum waveguide you milled? No way. Flush mount it and let it be seen!
Dan
How was the tweeter attached? I would recommend a gasket between the two."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Today I attended an auction of the shop tools in an OLD lathe shop. His HUGE lathe sold for $150 with all accessories. After seeing your WG, I'm thinking I should have bought it and installed it in my bedroom, since that's the only room left in my house. But, then I would have had to sleep with my wife. Turned out, I didn't needthat old lathe afterall.
- Likes 1
First observation is that the quality of the surface is excellent!
Second observation is that the throat is too deep. The sides at the opening are almost parallel and that will cause issues with response.
I'd remove a lot of the material from the back of the guide so that the opening starts with an angle of over 90 degrees.
That's beautiful! Makes me want to get a lathe.
With regard to mounting. I think it would be a shame to hide that big chunk of aluminum by fully flush mounting it. How about mounting it half flush mounted into the top of the woofer box with the top half sticking out, so that you can see how substantial the material is. Just a thought.
Cheers!
Joe
Originally posted by jml View PostThat's beautiful! Makes me want to get a lathe.
Cheers!
Joe
