Just FYI, I have added the companion speaker, the MTM LM-1C XSim files to the same discussion thread, for anyone who would like to look at those as well. The LM-1C measurements were probably a little off in terms of absolute level, and there was no near-field measurements at all, however it should prove educational.
Play with Crossover Design and Simulation - Free
I'm running into a strange issue comparing the results from WinPCD with those from XSim.
The first issue is minor differences in the predicted impedance curves. In this particular example (see pictures below) XSim is predicting a much higher high frequency impedance peak than WinPCD is predicting, for the same x-over components and driver impedance data. It's also predicting a slightly different response through the x-over region, which I guess is to be expected if the predicted impedance response curves are different.
2 PhotosBrian Steele
www.diysubwoofers.org
I'm pretty sure you probably got a decimal point wrong.
Trouble shoot it by removing first one filter (HP or LP) , then the other and comparing the impedance plot. You should see one section glaringly different. Alternatively you may need to substitute a 50-ish ohm resistor to keep things more normal.
Originally posted by ErikSquires View PostI'm pretty sure you probably got a decimal point wrong.
Trouble shoot it by removing first one filter (HP or LP) , then the other and comparing the impedance plot. You should see one section glaringly different. Alternatively you may need to substitute a 50-ish ohm resistor to keep things more normal.Brian Steele
Could the imported Z file be incorrect? Double check each driver's impedance by itself. Otherwise, come over to the XSim discussion at DIY. The author hangs out there often.I'm announcing the public release of XSim, a "free-form" Windows-based passive crossover design and simulation program intended to be as
Originally posted by ErikSquires View PostCould the imported Z file be incorrect? Double check each driver's impedance by itself. Otherwise, come over to the XSim discussion at DIY. The author hangs out there often.Brian Steele
Brian, just humor me.Take a look at the driver impedance drawn by XSim and see if the values make sense. It could be some odd read error, or perhaps you accidentally loaded the wrong file. It will take you 10 seconds.
I should also state I have a lot of confidence in XSim's impedance so far. I've designed 3 different 2 way speakers (1 was a center channel MTM), two of which are on my blog post, and compared the impedance to the actual measurements from DATS and they were spot on. Well, within the limits of part variance.
That does not mean something isn't wonky though.
Originally posted by ErikSquires View PostThat does not mean something isn't wonky though.
Brian Steele
Originally posted by ErikSquires View PostGlad you found it!
dlr
Hi Everyone,
Since a lot of viewers have gone from here to the LM-1 page I wanted to make sure you were aware of an oversight in explaining the project on my part.
When I say the LM-1 speakers are "bookshelf" speakers I mean exactly that. Their frequency response is designed for a desktop or bookshelf and as such need no more BSC than included. Sorry for any confusion caused. If you try these as standmounts you'll need to add some EQ. This is the opposite of most speakers designed quasi-anechoically, which then need EQ in a bookshelf.
This also means you should not compare any of my measurements with designs using quasi-anechoic techniques. Won't match up.
Perhaps a future project I'll re-work the crossover to make a stand-mount version. Or maybe a kind DIY community member will take that on for themselves.
Best,
Erik
